engine removal
engine removal
Is there a link to a good step by step to remove engine and transmission? Think im almost there but, reverse switch and just want to make sure im clear on final transmission disconnect from car.
When I did it I dropped the transmission with the engine and separated once out.
Double check all your lines are clear! I caught the hard fuel line going to the filter and bent it
Sorry - I don't have a resource. Next time I do it I'll make a vid!
thx guys. i have disconected the drive axles as well. and was hoping to pull the whole thing out.. motor n trans. is it just the shifter coupling in the floor pan..
You know about the access panel under the carpet just in front of the back seats? Just go through there and undo the coupling. Inspect it closely, the plastic bushings may be broken or worn oval, so you'll want to replace those.
Mark
Mark
Professor of Pending Projects
Here is a checklist I made for my 83 3.0, based on the 101 Projects book, another list I found on the internet, and first-hand experience. Yours will be a little different, but hopefully this is helpful.
Team Owner
pelican does have some really great resources for this . for me the key to the whole drop is the quality and make up of your engine dolly..
i took the wheels off and dropped the car on the dolly , undid the bolts and lifted the car off , it was a piece of cake.
I haddah Google dat
The only helpful tip I can add is to check, re-check, and check again that everything is disconnected and tied or pushed out of the way. Drop the car or engine a few inches at a time, not all at once. Re-check again. It's really easy to overlook a wire, harness cable, oil line, etc.
Team Owner
