87-89 shifter linkage - do we lube?
I replaced the bushings in the shifter mechanism and am about to reassemble. Unsure if I should lube (and with what) the shift rod at the new shifter housing bushing. Any thoughts? Thanks
I usually use a small amount of lithium grease. None is needed though.
Team Owner
ive moved into the modern era of synthetics. i might try some silicon based super lube next time .. i had lots left over from ....er... never mind
Thanks for the suggestions. I completed the job without any lube, but there seems to be a lot of friction on that new donut like bushing so I think I'll get back in there and give it a couple shots. Getting that bushing in and the rod back in was a beast. Just curious if I missed an easy set. Had it in 4th as suggested but still had a hell of a time.
