911 Forum 1964-1989
Nardi Wheel vs Momo
Old 10-21-2014, 10:31 AM
  #91
obscene
obscene's Avatar
cool photo of my prototipo courtesy wide911.com:
Old 10-21-2014, 11:28 AM
  #92
bhmkv
bhmkv's Avatar
Looks really good!
Old 10-21-2014, 04:35 PM
  #93
espanolie
espanolie's Avatar
nardi and momo both make great products. i'm a touch and feel guy so would need to see them both and see which would work better for my application. great input here - thanks all
Old 10-21-2014, 06:56 PM
  #94
HorstP
HorstP's Avatar
installing the Momo 07 made a night and day difference. The extra inches closer to the driver are very noticable
Old 10-22-2014, 11:35 PM
  #95
jpowers
jpowers's Avatar
flexbert,
Could you please take a side photo showing the eccentric adapter?
Thanks!
Old 10-23-2014, 01:38 AM
  #96
suckho
suckho's Avatar
Originally Posted by jpowers
flexbert,
Thanks!
Here is mine. Not exactly side view, but almost (welll.. 45 degrees or something). In this photo I have only eccentric adapter, but now I have both eccentric and normal adapters installed. Eccentric offset is ~1cm and both adapters are ~1/2" thick. I have plans to exchange that normal adapter to thicker one at some point to bring the wheel closer and especially more away from my right knee.
https://lh3.googleusercontent.com/-0...-no/14%2B-%2B1
Old 10-23-2014, 07:27 AM
  #97
flexbert
flexbert's Avatar
flexbert,
Thanks!
Here you go:
Old 10-23-2014, 07:31 PM
  #98
psychoideas
psychoideas's Avatar
Here's a Momo I bought for mine quite a while ago. I'll fit it one day.
Old 10-23-2014, 07:32 PM
  #99
psychoideas
With the horn pad just resting on.
Old 10-23-2014, 08:51 PM
  #100
jpowers
jpowers's Avatar
Default Eccentric adapter owners
Thanks for the two photos guys, I'm very tempted to get one as well but one question. Does it feel strange to have the center point of the wheel change as you turn the wheel?
Thank you
Old 10-23-2014, 09:24 PM
  #101
psychoideas
The original 3 spoke wheels are 25mm shorter from the shaft to the bottom as they are from the shaft to the top.
So I suppose the spacers just bring them back to standard.
Old 10-23-2014, 09:30 PM
  #102
psychoideas
Original wheel.
Old 10-23-2014, 09:54 PM
  #103
flexbert
flexbert's Avatar
Thank you
I don't notice it, other than if I make the effort to actually watch the steering wheel as I am turning it. And really, you shouldn't be watching the steering wheel when driving ....
The four spoke stock wheel on my car came standard with an offset upwards already i.e. the spline that attaches to the steering shaft is below the centre line of the wheel. To quote the JWest site (http://www.jwesteng.com/shop/index.p...roller=product), "Offsets the steering wheel 12mm upward and 16mm rearward. A similar offset is used on many factory 911 and 944 steering wheels". So, their eccentric actually makes the momo wheels have a similar offset in the vertical plane as the stock - that's my experience. The other advantage, IMHO, of the eccentric adapter is the offset rear wards, so the wheel is closer to the driver.
Old 10-24-2014, 01:24 AM
  #104
suckho
suckho's Avatar
Thank you
No. The original 3-spoke SC wheel is offset vertically as well.
Quick Reply: Nardi Wheel vs Momo
