I know where some of the oil is going
or a noggin of steel...anyways, all worked out and I know they are still solid. Car is running great. We'll see if the covers leak 'helps' my oil mileage (forever hopeful) totally dry under the car now.
Not steel...Dilavar!
Ed, thank you for the kind words.
Regarding oil loss through leakage, I've always suggested that loss from a leak, severe enough to affect consumption stats, can be explained easily by doing a very messy experiment. Take one-half quart of oil and spill it onto your garage floor. Let it sit there and spread out for a day.
Compare that monumental oil slick to the occasional droplet from the engine. You will quickly see that your oil leaks/drips will have to be very large before they will have any impact on your miles/quart consumption rate. Note; oil can stain concrete, so if you can use a large drip pan, available at most auto parts stores, it might be a good idea to use that instead of your floor.
For my next trick I will loosen all of the exhaust studs simply for fun!
Peter, I wasn't looking for an oil leak...was found during a valve adj and replaned the valve covers and don't expect much of a change.
and..the 2nd Amendment was not a hunting clause....
I have a question about this...is it true that minor leaks when parked generally do not leak signiificantly more when the engine is operating? I've always had concerns that when everything is pressurized, and the oil is warm and flowing, that the rate of leakage could be much greater.
My own '77 911S had a classic "no evidence left behind" leak. The engine oil cooler developed a pin hole leak, and when the car got up to temp, the oil shot out of that tiny hole; straight to the ground without hitting anything. Fortunately I caught that the oil level was down, but not low enough to cause further engine damage.
