356 Forum 1948-1965
Convert US wiring to European - rear brake wiring diagram
Old 04-09-2018, 03:50 PM
Bolti
Bolti's Avatar
Default Convert US wiring to European - rear brake wiring diagram
Hi can somebody supply me with a wiring diagram or instruction on how to convert the US wiring on my 1960 Porsche 356b to European brake and indicator
Old 04-10-2018, 10:11 AM
Walt L
Walt L's Avatar
Wink
Try 356 Registry for more details
Old 04-10-2018, 12:02 PM
zoomie50
zoomie50's Avatar
Default converting US to European-rear brake wiring diagram
Bolti. Here is a link for you: Sorry no wiring diagram: http://forum.porsche356registry.org/...=27939&start=0
Old 04-10-2018, 12:30 PM
zoomie50
zoomie50's Avatar
And here is how Mike Smith of PR Services in the UK recommends doing it: 1. We unsolder the Brake Single Filament Bulb Holder and pull it out - of course, only one holder per side needs changing (the Indicator Holder remains)
2. A quick clean up with a Dremel and the New Twin Filament Holders will just slide in and only require a dab of solder to produce a good earth and retain them
3. The Twin Filament holders are manufactured in the UK (all Brass) and I believe that they take a staggered pin bulb (I am at home so do not have one in front of me) – The wire connections are a small screw (a bit too small really but we have not had any come-backs)
4. When setting-in the new holders it is important to allow as much clearance as possible between the glass of the bulb and the Plastic Lens - if you sit with your foot on the brake the bulb generates a lot of heat and can melt the plastic
5. With regard to wiring, it is necessary to run a New Wire from the Brake light switch to one of the Tail units and then a link across
6. You will need the Red / Amber lenses also
Quick Reply: Convert US wiring to European - rear brake wiring diagram
