Bridgestone Potenza S-04s question & comment
Greetings, All:
Did a quick search on here, and didn't see Potenza S-04s mentioned much, if at all. Just got them put on today, and with only 20 miles on them, seem an improvement over the shagged P-Zeros that came with the 991 base model I have, but almost anything would, no?
Question - does anyone have pressure settings they use for street & also for track days that work with these tires? I set them at 38 psi (R), 34 (F) just to run around for now.
Also - the vehicle feels like it needs an alignment now, which it didn't when I took it in. Will that sensation go away, or is it likely that I DO need an alignment?
Thank you,
Syringe
Thank you,
Syringe
