The NEW 18" RS-808 Rotary Spun Light-Weight Concave WHEELS!
Former Vendor
RS-808 (Rotary Spin FORGED) $1599/set
18x8 (off-set 45) 18-lbs.
18x10 (off-set 50) 19-lbs.
Options: Hyper Silver or Satin Black
Compatible with PORSCHE factory lug bolts/nuts, center caps and Tire Pressure Monitors
The new RS-808 wheels are designed to be lighter and stronger over its predecessor 808-Series. This newer Rotary Spin design allows for a lighter built wheel while the flared spoke design helps to strengthen this wheel for spirited drivers.
These wheels are both VIA & JWL certified. No spacers, hub centric rings or adapters required for most Porsche applications.
Former Vendor
Sir,
These are offered in the 19" and 20" however the design is not identical and they are not the Rotary Forged design.
Go to our site to view the difference, we'd rather not post on this thread and confuse others scrolling quickly...
www.wheeldynamics.com
Former Vendor
I should let you know that we do have a custom build for those who want the 19" Flow Forged design wheels.
The price is $1999 on a set, we can offer you custom build off-sets at the same time. We can even offer brush finished sets for $2600, wheel weights will vary depending on the off-set and width but will vary between 22-24-lbs. on 19" versions.
The lead time for standard builds is 1-2 weeks and 2-3 weeks for brush finish builds!
Let us know if this might be something to your liking!!!!
