911 GTS question
911 GTS question
Ok wheel experts,
For 2015-2016 GTS 911 Will a summer turbo s wheel (same year) stock from factory correct) fit on a GTS? Will it accept both summer and winter rubber?
On tirerack when searching for center ms fir a turbo there are two rears that show up. 11 and 12 inch. Which one should I be choosing got a 2016 GTS.
Thanks.
Thanks.
I assume you are referencing the center lock wheels. Turbo wheel has a 56mm offset vs. 46mm for the GTS. Turbo wheel will move in 8mm. There will be enough clearance from the strut, but the outer edge of the wheel also moves in 8mm which may not look "aggressive" like the current GTS wheel.
