OZ and TireRack introduce the Leggera HLT
Thanks for the update and I assume those in the pic below are 20's? I would like to see these in 19in on a Black C4S...speaking of...will these fit the wide body cars?
From another post, just wanted to share what these look like with others. Just got these in yesterday. 20 in OZ Leggera HLT - Bright Race Grey 20x8.5 +55 22lbs and 20x11 +50 24lbs. Really love the way these turned out. I'm thinking some spacers for the rear to push them to the edge. Is it safe to run spacers on the track? I'll get some more pictures once I get it cleaned up on Saturday.
The 19" wheels recommended for 2010 Cayman/Boxster by OZ and Tirerack sites are 8.5"+53 / 10"+40.
Are there 9"/10.5" or 9.5"/11" Z wheels that fit?
Former Vendor
Available fitments are:
19X8.5 5-130 ET53
19X10 5-130 ET40
19X11 5-130 ET50
19X11 5-130 ET65
19X11 5-130 ET40
19X12 5-130 ET51
20X8.5 5-130 ET55
20X8.5 5-130 ET50
20X9 5-130 ET50
20X10 5-130 ET45
20X11 5-130 ET50
20X11 5-130 ET65
20X12 5-130 ET51
Former Vendor
Do these use conical or ball seat lug bolts/nuts? What size/spec lug bolts do you recommend for a 19x8.5 ET 53 front and 19x11 ET 50 rear? Can the stock OEM bolts be used on a 997.2 narrow body?
mine where for Boxster 8.5"/10" and used stock lug bolts and correct center bore.
They don't make a properly fitting 9" front. 11" is getting pretty wide for the rear, also. You would probably need an aggressive alignment to get them to fit.
19X8.5 5-130 ET53
19X10 5-130 ET40
19X11 5-130 ET50
19X11 5-130 ET65
19X11 5-130 ET40
19X12 5-130 ET51
20X8.5 5-130 ET55
20X8.5 5-130 ET50
20X9 5-130 ET50
20X10 5-130 ET45
20X11 5-130 ET50
20X11 5-130 ET65
20X12 5-130 ET51
19X8.5 5-130 ET53
19X10 5-130 ET40
19X11 5-130 ET50
19X11 5-130 ET65
19X11 5-130 ET40
19X12 5-130 ET51
20X8.5 5-130 ET55
20X8.5 5-130 ET50
20X9 5-130 ET50
20X10 5-130 ET45
20X11 5-130 ET50
20X11 5-130 ET65
20X12 5-130 ET51
19X8.5 5-130 ET53
19X11 5-130 ET50 would work even though it's not listed on the website.
I checked and the front is offered as an option. the rear will probably require a spacer.
Damon, has anyone checked if the 19x11 would fit in a 43 to 45mm offset? via 5 -7 mm spacer?
