Where can I buy extra long screw in wheel studs?
I'm installing some Kinesis K58 hoops on the p-car, 2005 987 3.4 creation. For my application, I'm running 30 mil spacers in the rear yowzers.
Everything bolts up fine with the H&R spacer kit. The kit has bolts that secure the spacer to the hub and then you use the stock wheel lug bolts to hold the wheel on.
I would much rather have longer studs and normal lug nuts as I have been running previously with 15 mil spacers. That way you eliminate the extra bolts and also its much easier to put the wheels on.
I am having trouble sourcing the studs. I need screw in studs that measure 12mm x 1.5 and 3.25" long.
Any ideas?
Any ideas?
