TireRack is Proud to Now Offer Toyo Race Tires
After many years trying to get the Toyo brand in our lineup, it has finally happened! Inventory is on it's way in and many sizes are now in stock. Initial sizes and pricing (subject to change) is below.
Proxes RA1 Track & Competition DOT – Racetrack and Autocross Only
205/60R13 TO PROXES RA1 132.00
205/50R15 TO PROXES RA1 149.00
225/45R15 TO PROXES RA1 159.00
225/50R15 TO PROXES RA1 165.00
225/50R16 TO PROXES RA1 206.00
245/45R16 TO PROXES RA1 215.00
255/50R16 TO PROXES RA1 214.00
235/40R17 TO PROXES RA1 209.00
255/40R17 TO PROXES RA1 197.00
275/40R17 TO PROXES RA1 220.00
275/35R18 TO PROXES RA1 268.00
Key Points:
Meets DOT requirements for street driving
Its the Spec tire for many NASA race classes, including Spec. Miata
Reputation for very long wear and good resistance to heat cycles
Often fastest right before the end of it's life
Works great in wet at full tread depth
Works with relatively wide window of set up and driving styles
Stepped tread pattern becomes a virtual slick at 2/32nds depth
Operating temperature is 160-220 F
Target HOT Pressure 32-38 psi.
Recommended camber -2.5 to -5 degrees
Proxes R888 Track & Competition DOT – Racetrack and Autocross Only
185/60R13 TO PROXES R888 141.00
205/60R13 TO PROXES R888 142.00
225/45R13 TO PROXES R888 155.00
205/55R14 TO PROXES R888 149.00
225/50R14 TO PROXES R888 157.00
195/50R15 TO PROXES R888 128.00
205/50R15 TO PROXES R888 147.00
225/45R15 TO PROXES R888 161.00
225/50R15 TO PROXES R888 167.00
235/50R15 TO PROXES R888 186.00
195/50R16 TO PROXES R888 185.00
205/55R16 TO PROXES R888 202.00
225/45R16 TO PROXES R888 205.00
225/50R16 TO PROXES R888 202.00
245/45R16 TO PROXES R888 223.00
255/50R16 TO PROXES R888 215.00
205/40R17 TO PROXES R888 203.00
215/45R17 TO PROXES R888 209.00
225/45R17 TO PROXES R888 217.00
235/40R17 TO PROXES R888 210.00
235/45R17 TO PROXES R888 229.00
245/40R17 TO PROXES R888 231.00
255/40R17 TO PROXES R888 204.00
275/40R17 TO PROXES R888 219.00
315/35R17 TO PROXES R888 282.00
225/40R18 TO PROXES R888 246.00
235/40R18 TO PROXES R888 241.00
245/40R18 TO PROXES R888 255.00
255/35R18 TO PROXES R888 248.00
265/35R18 TO PROXES R888 300.00
275/35R18 TO PROXES R888 270.00
275/40R18 TO PROXES R888 352.00
285/30R18 TO PROXES R888 346.00
295/30R18 TO PROXES R888 260.00
305/35R18 TO PROXES R888 299.00
315/30R18 TO PROXES R888 299.00
335/30R18 TO PROXES R888 332.00
235/35R19 TO PROXES R888 303.00
265/30R19 TO PROXES R888 336.00
295/30R19 TO PROXES R888 311.00
305/30R19 TO PROXES R888 409.00
285/35R20 TO PROXES R888 378.00
315/30R20 TO PROXES R888 397.00
Key Points:
Faster than an RA1, but works best within a more narrow sweet spot window
Proxes TQ Track & Competition DOT – Streetable Drag Racing Radial
P255/50R16 TO PROXES TQ 153.00
P275/45R16 TO PROXES TQ 157.00
P275/40R17 TO PROXES TQ 170.00
P315/35R17 TO PROXES TQ 176.00
P345/40R17 TO PROXES TQ 184.00
P315/35R18 TO PROXES TQ 261.00
Proxes R1R Extreme Performance Summer
195/50R15 TO PROXES R1R 110.00
195/55R15 TO PROXES R1R 118.00
205/50R15 TO PROXES R1R 122.00
225/45R15 TO PROXES R1R 139.00
205/45R16 TO PROXES R1R 140.00
205/50R16 TO PROXES R1R 137.00
205/55R16 TO PROXES R1R 147.00
225/45R16 TO PROXES R1R 151.00
225/50R16 TO PROXES R1R 152.00
215/45R17 TO PROXES R1R 164.00
225/45R17 TO PROXES R1R 176.00
235/40R17 TO PROXES R1R 148.00
235/45R17 TO PROXES R1R 175.00
245/35R17 TO PROXES R1R 182.00
245/40R17 TO PROXES R1R 156.00
245/45R17 TO PROXES R1R 188.00
255/40R17 TO PROXES R1R 191.00
275/40R17 TO PROXES R1R 204.00
225/40R18 TO PROXES R1R 165.00
245/40R18 TO PROXES R1R 180.00
255/35R18 TO PROXES R1R 220.00
265/35R18 TO PROXES R1R 220.00
Key points:
A favorite in many SCCA Street Tire Autocross classes
Very good blend of dry and wet grip for an Extreme Performance summer tire
It has a great reputation for performing well in cooler dry conditions
Some autocrossers say it can overheat easily
Great news. Don't forget to call me, use my link in my signature to order Thanks!
Key Points:
Key Points:
Key points:
