What are the different Fuchs offsets?
I am looking for the different Fuchs offset for 944s and 911s?
944 Fuchs(are these correct?)
.............83-86......87-88
15x7......23mm.......52.3mm
16x7......23mm.......52.3mm
16x8......23mm.......52.3mm
911 Fuchs(have no idea)
15x7
16x7
16x8
Could someone fix my mistakes and fill in the 911 Fuchs offsets? I am just concerned with Fuchs wheels in these sizes.
What year did they start and stop making Fuchs for 944s and 911s?
Thanks, also if you know of a link to a chart that has this info that would be great also.
15x7
16x7
16x8
Fuchs can only be used in '83-86 cars because they no Fuchs were ever made with the required 52.3mm offset for the '87+ cars.
Here's some part#:
6JX15
911-361-020-10 36.0mm
911-361-020-90 36.0mm
7JX15
911-361-020-41 23.3mm
911-361-020-93 23.3mm
8JX15
911-361-020-42 10.6mm
911-361-020-94 10.6mm
6JX16
911-361-020-43 36.0mm
911-361-020-97 36.0mm
or
911-362-113-00 36.0mm
911-362-113-90 36.0mm
8JX16
951-362-117-00 23.3mm
951-362-117-90 23.3mm
(I seemed to have lost the part# for the 16x7" Fuchs front wheel for 944Turbos. If someone can give me that part#, I'd appreciate it greatly.)
All '83-86 944 NA cars can use the 911 Fuchs. But only the part# starting with 951 can be used on the '86 944Turbo. That's because the arms/spokes have extra clearance for the 944Turbo's big brake calipers.
Here's some part#:
6JX15
7JX15
8JX15
6JX16
or
8JX16
Thanks Danno, that's just the info. I was looking for.
I found a pair of 16x7s on line that came off of a 911 that I may buy, are these the same as the 16x7 Fuchs front wheel for the 944Turbos?
Thanks, I will see if I can get that PN for you.
Technical Specialist
Lifetime Member
Lifetime Member
I believe the answer is no, 911 16x7's and 944 16x7's are shaped differently, to account for larger 944 calipers, even though they have the same offset and backspacing.
My set of Fuchs on my 85 NA are:
FRONT - 911-362-115 7Jx16
REAR - 951-362-117 8Jx16
They work great.
I would like to transfer them over to my new 86T but as stated above, the 911-362-115 spokes hit my calipers. Does anyone make a spacer for this application?.
They work great.
