Nail in sidewall - Do I buy 1 or two new tires?
Got a nail in the shoulder/sidewall area of right rear bridgestone RE-050A. The good tire on the left rear has an honest 6-8/32nds tread remaining. Is replacing only one just fine? These are my street tires, not pushed too hard
Jim
Jim
You don't trust the five responses we supplied on planet-9?
But now you say "an honest 6-8/32" instead of 8/32. Whatever it is, you can have Tire Rack shave your new tire down to match the other tire's diameter.
A new tire is either about 9/32's or 10/32's. What is the code date on the tire you want to keep? Do you have PSM (Porsche Stability Management)?
You need to measure with one of these, no guessing. These's no such thing a 6-8/32's. Measure, and you'll know for sure.
Of course I trust planet-9 as much as rennlisters, I just didn't know how much overlap there was among mempership.
The change in remaining tread depth is because I was looking harder last night, and noticed the good tire had slightly less tread remaining than the damaged tire that I measured the first time, so when I posted here I was able to be even more precise. I used a depth guage on a micrometer to measure, and the range is inside vs outside depths, due to wear from camber.
Thanks,
Jim
With those cambered wear measures, I'll defer to Damon or Jim at Tire Rack. If advised, maybe they can even shave the new tire to match your remaining tire's inside to outside measures.
This is a little off topic, but I have a blown tire that continues to leak. It's becoming a hassle to keep filling it with air. I was thinking of purchasing a new one from Tires-easy.com (noticed they have great pricing), but I'm a little hesitant to order online. Anyone have experience ordering from Tires-easy.com? Thanks.
