FS - 18" or 17" Kinesis k27's built to spec / any width / custom
Want a custom set of 5x130 Kinesis K27's with polished faces, built to whatever width desired in 18" OR 17"?
![](https://i674.photobucket.com/albums/vv106/thatchershultz/k27051.jpg)
I can build these K27's as 18's or 17's. As narrow as 7.5", as wide as 14". Whatever you want (to a certain extent, I only have so many inners and outers available). Offsets would obviously depend on width.
Here are three width / offset examples of how these could be built (For these scenarios, I used a 7.5" inner. Keep in mind, if I built them with a wider inner, the offset would get higher. If I use a narrower inner, the offset would get lower. The two rear centers have a thicker center pad, creating a lower offset, and the two front centers have a narrower center pad, creating a higher offset):
Rear lower offset center built as a 9" wide wheel with 1.5" outer and 7.5" inner, 51mm offset
Front higher offset center built as a 9" wide wheel with 1.5" outer and 7.5" inner, 65mm offset
Rear lower offset center built as a 10.5" wide wheel with 3" outer and 7.5" inner, 32mm offset
Front higher offset center built as a 10.5" wide wheel with 3" outer and 7.5" inner, 47mm offset
Rear lower offset center built as a 12" wide wheel with 4.5" outer and 7.5" inner, 13mm offset
Front higher offset center built as a 12" wide wheel with 4.5" outer and 7.5" inner, 28mm offset
Prices:
17" set - $2150 + $95 shipping
18" set - $2490 + $125 shipping
*one of the rear centers has a custom 15mm spacer bolted onto the back side of the center, as this was a replacement center with a thinner pad (it needed the custom spacer to make it the same as the other side). If it weren't for this detail, the prices would be higher.*
18x1.5" outer:
![](https://i674.photobucket.com/albums/vv106/thatchershultz/k27042.jpg)
18x5.5" outer:
![](https://i674.photobucket.com/albums/vv106/thatchershultz/k27043.jpg)
17x2" black outer:
![](https://i674.photobucket.com/albums/vv106/thatchershultz/k27049.jpg)
![](https://i674.photobucket.com/albums/vv106/thatchershultz/k27053.jpg)
thatcher.shultz@gmail.com
Prices:
18x1.5" outer:
18x5.5" outer:
17x2" black outer:
