Wheel and Tire Forum
Tire Question (premature wear due to alignment issue)
Old 03-31-2008, 12:56 PM
Rob in WA
Cap'n Insane the Engorged
Rob in WA's Avatar
Default Tire Question (premature wear due to alignment issue)
Wifey had new tires ( Yokohamas) put on the A4 last October at Discount Tires, always been happy w/them. Tires are guaranteed for 60k miles. Yesterday she gets a flat. I go to help her change it and see both rears are bald on the inside down to the cords. Obviously her alignment is way off. She's just called from Discount Tires ( upset ) and they're making her buy new tires.
If the alignment was that far off, wouldn't they be obligated to say something to her?
And if not, shouldn't the tires be guaranteed no matter how bad the alignment?
Old 03-31-2008, 01:03 PM
Gretch
Range Master
Pepsie Lite
Gretch's Avatar
Received 1,235 Likes on 755 Posts
Nope, sorry. Alignment is an owner issue. Heck, look at the alignment on the rear of carreras........... and that is OEM!
Old 03-31-2008, 01:04 PM
streckfu's
streckfu's's Avatar
An alignment check is a separate maintenance action from mount and balancing tires. If you didn't ask for it, they don't check it.
Nope. Bad alignments can destroy tires, so they won't cover them if it is shown your alignment is that bad.
Old 03-31-2008, 01:08 PM
jimbo3
jimbo3's Avatar
Obligated to say something? No, but it would be good business to do so if they knew of an alignment problem. Then again, how would they know or anticipate an alignment problem?
On the warranty, it depends on what the warranty says, but I'll bet it says something about "normal wear", which this obviously isn't as you've pointed out. I don't think it would be reasonable for the tire company to assume liability for one's maintenance issues.
Why, exactly, are they denying the warranty claim?
Old 03-31-2008, 01:20 PM
Rob in WA
Rob in WA's Avatar
I guess it depends on the small print in the warranty.
The alignment was off when they put the tires on.
Say, when we notice they're going bald, we get the alignment done. Then bring it back to Discount Tires to honor the warranty.
The warranty off their website:
The mileage warranty of a tire indicates the number of miles that a tire is estimated to last. If a tire fails to last for the number of miles indicated by the warranty, the customer will be given credit toward a new tire based on how many miles short of the estimate the tire fell. Some restrictions apply.
They must have alignment specs as a restriction - oh well.....
Old 03-31-2008, 01:22 PM
Jaak Lepson
Rest In Peace Jaak
Cable Guy
Jaak Lepson's Avatar
Talking
Should post this in the Tire Forum ..... just sayin' ....
Old 03-31-2008, 01:25 PM
streckfu's
streckfu's's Avatar
If you only ask for a mount and balance, that is all you will get.
Chalk it up to a learning experience.
Old 03-31-2008, 01:31 PM
WalkerInTN
WalkerInTN's Avatar
You can't seriously expect them to cover your mistake.
I'm sorry, but it's not Discount Tire's fault that you don't have a proper alignment on your car, which caused premature tire wear. That's your fault for not properly maintaining your vehicle.
Old 03-31-2008, 01:35 PM
User 462021
User 462021's Avatar
Believe it or not, but your alrignment on your car can go bad pretty quickly.
Old 03-31-2008, 01:36 PM
User 462021
Oh, and tire manufactures NEVER will warranty a tire because of abnormal wear if its caused by your alignment. However, if you talk to the right person with Yokohama they may make a deal with it. Happens all the time.
Old 03-31-2008, 01:40 PM
jimbo3
jimbo3's Avatar
Maybe I'm not reading this correctly but, if you knew the alignment was off when you were getting new tires, why didn't you have them do the alignment at that time?
Old 03-31-2008, 01:42 PM
designman
designman's Avatar
How long did the previous set of tires last? Both tires going so quickly and consistently on both sides sounds suspect. Somethin' doesn't add up here. I wouldn't be going back to that place.
Old 03-31-2008, 01:50 PM
Rob in WA
Rob in WA's Avatar
I didn't know the alignment was off. I would've had it done if I had.
Discount Tires doesn't do alignments, at least not this store.
Tires lasted five months, about 5k miles.
It's no big deal, she's just pissed.
Old 03-31-2008, 01:56 PM
Randy V
Randy V's Avatar
Moved to the Wheel and Tire forum.
Yes, there really is such a place!
Old 03-31-2008, 01:57 PM
streckfu's
streckfu's's Avatar
Obviously the shop owner is a fiberalcon......can it be moved back to OT now?
Quick Reply: Tire Question (premature wear due to alignment issue)
