Effects of unsprung (and other) weight - wheels, etc.
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
On another forum that I am on someone asked a question about the impact and effect of aditional rotating mass (ie. larger heavier wheels).
I don't know of any valid calculators out there. They would really need to take into account where the weight is located on the wheel. Weight located farther away from the center takes more effort to rotate than weight located in the center.
As an example, take a hammer, place it on a table, and spin it by the bottom of the handle (wooden part). Now spin it by the top (metal part). You can easily feel that it easier to spin the hammer when the metal hammer part is in the center.
Obviously larger rims have their weight farther from the center than smaller rims. Therefore 16" rims will take less force to rotate than 19" rims of the same weight.
That being said, I have heard of a basic rule of thumb. Rotational mass is equivalent to 3x stationary mass. E.g. For every pound of rotational mass added, would be like adding 3lbs of lead to your car.
In your case you are adding 11lbs per corner (that is a lot). So that is 44lbs total rotational mass added. To estimate the effect on acceleration, it would have the same effect as adding 132lbs of lead to your car.
The addition of rotating mass affects braking in the same way (think of it as negative acceleration).
Also because wheels are un-sprung weight, it negatively affects your handling abilities and road comfort as well. It basically means more work for your shocks and springs when handling bumps.
-Scott
Anyone have any links/calculators or anything that demonstrates the impact of wheel (tire+rim) weight on the 1/4mile?
I'm looking at some tires/rims that are about 56lb per corner. My current ones are roughly 45lbs per corner. The advantage of the heavier ones is that they're 17x8 (255/45/17) vs my current 17x6.5 (225/55/17)... I'm guessing the weight would have a noticeable impact on my 1/4mi times....but so might the wider rim/tire....?
-Scott
Unsprung weight not only includes the wheels but the rotors, calipers and a portion of the shock and suspension bits.
Here's a chart I created on wheel weights. Let me know if you have add'l data points, add'l wheel info, etc.
http://members.rennlist.org/911pcars/WheelWts.html
Thanks,
Sherwood
Thanks,
Sherwood
Factory 996 Turbo Hollows
8x18" at 22 lbs 2oz
11x18" at 26 lbs 5 oz
Factory 996 Turbo Solids
8x18" at 26 lbs 2 oz
11x18" at 31 lbs 6 oz
Factory GT2 wheels (earlier years, Turbo Solids):
8.5x18" at 28lbs 11 oz
12x18" at 33 lbs 0 oz
Factory GT2 wheels (later years, GT3 style)
8.5x18" 25 lbs 2 oz
12x18" 29 lbs 0 oz
Factory GT3 wheels
8x18" 22 lbs 10 oz
11x18" 27 lbs 11 oz
Fiske Profil 13:
8.5X18 = 21 lbs.
12X18 = 22.5 lbs.
19" Dymags for 997S
16 lbs., 0 oz. front
19 lbs., 0 oz. rear
BBS RS-GT
19x8 21 lbs
19x11 24 lbs
F1 x r1 = F2 x r2
where F1 is one force and F2 another and r1 is one radius from the fulcrum and r2 another. Now force is a product of mass times acceleration( F = m x a) and the goal here is equal acceleration under both conditions, so we can say
F1 = m1 x a1 and F2 = m2 x a2 where a1 = a2 so we will just say 'a'
this yeilds the formula
m1 x a x r1 = m2 x a x r2
since the acceleration is the same, we can divide both sides by a and get
m1 x r1 = m2 x r2
now if we say r1 to be 9.5 inches, the radius of a 19 inch wheel and r2 to be 8 inches, the radius of a 16 inch wheel, we get
m1 x 9.5 = m2 x 8
dividing 9.5 by 8 we get 1.1875, so
m1 x 1.875 = m2
so a 19 inch wheel can have 1.875 times the mass at its rim than a 16 inch wheel and still be accelerated at the same rate with the same ammount of torque.
Think about closing a door. It's much easier to close a door by the handle than it is by the inner side of the door where the hinges are.
This is one reason stepping up the diameter of your wheel is not as bad as one would excpect, since most of the mass of a wheel is in the rim. Also, you have to factor in the weight of the sidewall. A 16 inch tire of the same brand and width is going to weigh more than the equivalent 19 inch tire because it has more sidewall.
Todd
I picked up this info (mostly 996 vintage) on a multiple forums over the past few years. I didn't take the measurements, so not sure of accuracy but they seem reasonable.
8x18" at 22 lbs 2oz
8.5x18" 25 lbs 2 oz
12x18" 29 lbs 0 oz
Factory GT3 wheels
8x18" 22 lbs 10 oz
11x18" 27 lbs 11 oz
Fiske Profil 13:
8.5X18 = 21 lbs.
12X18 = 22.5 lbs.
19" Dymags for 997S
19 lbs., 0 oz. rear
BBS RS-GT
19x8 21 lbs
19x11 24 lbs
8x18" at 22 lbs 2oz
8.5x18" 25 lbs 2 oz
12x18" 29 lbs 0 oz
Factory GT3 wheels
8x18" 22 lbs 10 oz
11x18" 27 lbs 11 oz
Fiske Profil 13:
8.5X18 = 21 lbs.
12X18 = 22.5 lbs.
19" Dymags for 997S
19 lbs., 0 oz. rear
BBS RS-GT
19x8 21 lbs
19x11 24 lbs
Here's what I collected from various sources (rennlist/6speed/vendors/friends - thanks to all)
CCW
c10 (estimated)
18x9 Front 19.4lbs
18x11 rears 20.6lbs.
T10s
18x9 front 20 lbs front
18x11 rear 21-22lbs (estimated)
C14 (estimated)
9 Front 21.5lbs
18x9.5 front 22lbs est.
18x10 front/rear 23lbs
18x11 rear 22.5lbs
18x12 rear 24lbs
BBS
The BBS Racing wheels on datax's car (aluminum centers):
18" x 8.5": 19 lbs
18" x 11": 21 lbs
The BBS Racing Magnesium centers
18" x 8.5": 20 lbs
18" x 11": 22 lbs
Champions
RG5
18x8 front 18.5lbs
18x8.5 front 19 lbs 2 oz.front
18x10 rear 19.5lbs
18x11 rear 19lbs 9 oz.
HRE Competition Series
8.5x18” 19 lbs. 5 oz.
11x18” 20 lbs. 4 oz.
Volks
TE37
18x8.5 18.5lbs (bathroom scale teseted too)
18x9 front 18.5lbs (estimated)
18x10 rear 19.5lbs
18x11 rear 20.5lbs (bathroom scale tested too)
19X8.5 20lbs
19X11 21.5lbs
Wheel Dynamics 02 5 spokes (Boxster fitment)
18x8 front 23lbs
18x9 rear 26lbs
Porsche/BBS
18" Sport Designs
7.5" Front 26.5lbs
10" Rear 30lbs
18" 02' Carrera2 5 spokes
7.5x18" 20 lbs. 9 oz.
8" Front 21lbs
9x18" 22 lbs. 13 oz.
10" Rear 23lbs
Porsche Factory 2002 996 Carrera 10-spoke
7x17" 18 lbs. 1 oz.
9x17" 20 lbs. 15 oz.
Porsche Carrera Sport
19" x 10": 27 lbs
19" x 11.5": 29 lbs
Porsche Sport Technos (hollow spoke)
Front 8x18" 20lbs, 11oz
Rears 11x18" 25lbs 8oz
993 18" Turbo Twists (solid)
18x7.5" Front (50mm) 24.5lbs
18x10" Rear (65mm) 28lbs
Another good site that matches OEM and some Aftermarket wheels with corresponding pictures and weights.
http://www.944racing.de/reload.php?u...elweights.html
This principle of physics isn't entirely accurate and actually the opposite. Consider the following formula dealing with different torque forces.
F1 x r1 = F2 x r2
m1 x r1 = m2 x r2
m1 x 9.5 = m2 x 8
m1 x 1.875 = m2
Todd
F1 x r1 = F2 x r2
m1 x r1 = m2 x r2
m1 x 9.5 = m2 x 8
m1 x 1.875 = m2
Todd
" m1 x 1.875 = m2
so a 19 inch wheel can have 1.875 times the mass at its rim than a 16 inch wheel and still be accelerated at the same rate with the same ammount of torque. "
I was with you right up to the conclusion. The equation says M1 the mass of the 19 inch wheel is multipled by 1.1875 to get the weight of a 16 inch wheel of equal acceleration. So the 16 incher (M2) can weigh MORE than the 19 incher (M1). Substitute some numbers for M1 and M2 to verify. A 10 lb 19in wheel will be equivalent to a 11.8 lb 16 inch wheel.
Yes, you guys are absolutely right. I guess doing math on valuum is not a good idea. That's also probably why you guys drive 996s and I drive those fake front engine VW/Audi/Porsches.
I'm also thinking about this whole thing backwards. It is easier to break a tough bolt when you move further away from the fulcrum, like using a longer breaker bar, just like the closing a door example I used before. But that is the exact opposite of what we are dealing with. If you think about it like swinging your keys on a lanyard keychain. It would take more force to swing those same keys on a 5 foot long string it would take more effort.
The final verdict: I was wrong. I need to stop trying to sound smart when I take my pain medication. I basically proved the point that I was arguing against.
Hopefully this at least brought a mathmatical proof to what's going on here, even though I look like a complete jackass.
Todd
Todd
Todd, don't be so hard on yourself. And more importantly, don't be so hard on on the front-engine VW/Audi/Porsches.![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
We all make mistakes, that's how we learn. At least you were smart enough to realize it, and man enough to admit it, unlike alot of people on this board (including me, sometimes).
Todd,
I agree with Moorepower, no worries, it's a good discussion. The 944T is the only car I ever bought twice and is still one of my favorite P-cars. Everytime one goes by I get the urge to buy another.
Todd
Todd
The same goes for the door. It would be easier to close the door if most of the mass where located close to the hinges (inside part of the door), instead of the outside part.
-Scott
Lightweight is good but getting lighter at the price of rigidity may have some unwanted consequences. Here is an article that is a good read (I think vivid racing posted this same article as well but this site's version is a little easier to read).
http://og-made.com/archives/1904
In a nutshell the lighter wheels were faster in certain parts of the track but the more rigid wheels were able to attack the corners more aggressively. The rigid wheels were faster in the end.
The article echos my conversation with CCW when I was inquiring about the C10s. They said that they could shave the wheels to make them lighter but that they wouldn't be as strong.
The website link: http://og-made.com/archives/1904
..... makes an oversimplification, IMHO.
Rigidity and relative lightness are not necessarily independent variables. You can have both. RE: Fuchs. And it's all relative to a reference point.
In that the the wheels in their test included those that were:
1) rigid (retail wheel)
2) less rigid, but lighter (lightened version of retail wheel)
......doesn't necessarily prove that rigid (and thus heavy) is better than light (but equally rigid). I would guess that particular wheel design doesn't lend itself to lightening modifications w/o a loss of rigidity.
Me thinks the article is an advertising plug in the guise of a technical test; "Although my company's wheels are heavier, their rigidity (and weight) is more important when it comes to track results." Nah.
Sherwood
Sherwood
In the end, I think that the article calls for a good balance of weight and rigidity.
"In summary, Kobayashi expressed that a balanced wheel with both rigidity and lightweight characteristics is important, but he never imagined that the effects of rigidity played such a large role."
They could probably stand to do more testing, but I think they still bring up some things to consider. If you have two equally lightweight wheels, the more rigid one will probably do better.
Expanding a bit to include 18" wheels vs 17" wheels, per the rennlist 996 faq, "Track drivers favor 18" for their larger contact patches and thinner sidewalls which deform less under hard cornering. Auto-X drivers favor smaller wheels for less weight and sharper turn-in."
https://rennlist.com/996_faq/b.htm
