5.5x14" fuchs
Does anybody know if I can fit a 205/55s on this rim??
I currently run 195/60s race rubber which needs to be replaced and I want to go with the Kumho V700. available sizes are 195/55 and 205/55.
Comments feedback anybody with experience with these tires??
Brgds, Peter
Brgds, Peter
Brgds, Peter
Brgds, Peter
Well, I must say, the response to this thread has been overwhelming....
FYI - I gambled and 205/55/14s work just fine. The inside rears did touch the ecentric bolt in the trailing arms under load but only just. I might add a spacer or grind the bolt down. Static clearance is about a 1/4 inch in the rear. No issues in the front.
Could Tirerack.com apprise you?
