Reversing tire Rotation
My tire guy suggested when I remount my Michlein Pilots that I flip them all around so that they all rotate in the opposite direction as previously mounted and indicated by the arrow on the tire. He said the tires would wear longer.
Makes me think he is crazy.
Before I do this... or not, what does the group say.
The arrows on the tires are there for a purpose. i don't think your tire guy knows what he's talking about. The Pilot's are directional, not unidirectional.
Cows-4-Rent
Yes, they will wear longer. It is usually the shoulders that get the most amount of wear from turning. the tread is usually the last to go.
The arrow on the tire is there for direction but only for channeling water out from under the tire. I don't drive my cab in the rain or snow, so I can flip them. We flip our race tires regularly to increase wear.
If you're running in dry only conditions, go ahead and flip them. If not, better to mount in the direction that they are intended.
Former Vendor
You can do it, but it will sacrifice hydroplane resistance. You may also notice an increase in tread cap separation of the plys as they are usually laid at 45 degree angles against the direction of inteded rotation. You'll just have to watch for the feathering to start.
