R compound DE tires-MPSC, Dunlop SSR, Pirelli Corsa
What to get. MPSC, Dunlop SSR or Pirelli Corsa. I will only be using these at the track. Both the Dunlop SSR and Pirelli Corsa seem to be 250-300 less a set then the MPSC. I want to be able to flip the tires from one rim to the other to maximize use. I haven't read a lot about the Corsa or the Dunlop SSR. It seems the MPSC is the fastest and best handling. Does it wear 25-30% better then the others to make up for the price difference? Thanks a lot.
Ken
Ken
I had tried a set of the 1st generation pzero corsa's and they got super nasty dry rot cracks after just 4 summer months... I'll never try another corsa again after that experience!
I talked to someone else who had similar problems with their pzero race tire (non dot)
...unless the new corsa has changed a lot.. I wouldn't trust it!
Technical Specialist
Lifetime Member
Lifetime Member
Scan the archives, especially in the racing forum (believe you posted there too), as this is an often discussed topic. James Archard has a recent post there where he summarized the current 'views' on the various R compound tires.
