996 wheels
996 wheels
Hello I'm new in the Porsche world just got myself a 2003 996 carrera4 cabriolet. The wheels the car came with are not originals,
I'm looking at these turbo twist 18 inch wheels
Front: Size: 18x8 Offset: ET50 Tires: 225/40/18 Part Number: 996.362.136.01 Rear: Size: 18x10 Offset: ET47 Tires: 265/35/18 Part Number: 996.362.140.01.
Don't really understand the offset.
Anyone know if these will fit or if this has already been discussed can you share the thread so i can look into.
The front should be no problem, the rears might be tight with that tire could possibly clear depending on how square the rear tire is and that can vary by brand. I would suggest something with a higher offset in the rear like 50-65mm and then you can play with spacers if you want.
Has what looks like good info.
https://support.apexraceparts.com/hc...-Fitment-Guide
Some original info
https://www.wheel-size.com/size/porsche/911/2003/
Some original info
