718 GT4 Track Wheel Setup
I'm running Forgelines 9" wide front 10.5" wide rear.
I have an order for Apex SM-10 wheels also as a second set of track wheels.
Basic Sponsor
Our popular go to setup is Titan7 TS5s.
Let us know if you're interested.
-Josh
-Josh
Your #1 Dealer for Aftermarket Performance Products
BC Forged / Soul Performance / Akrapovic / Bilstein / HRE / AL13 / CSF + more
Orange County, CA
Email: info@merakiautoworks.com
Text/Call: 213 394 2886
Website: www.MerakiAutoworks.com
Orange County, CA
Basic Sponsor
Front 19x9" ET50 // rear: 19x10.5" ET44
This is available in our SM-10 and VS-5RS fitments and has a wide selection of tire availability which you can see on our 718 GT4 Wheel and Tire Fitment Guide HERE.
Since this is a dedicated track car, our preferred tire sizes are 265/35-19 front, and either 295/35-19 or 305/30-19 rear. Many enthusiasts also run 285/35-19 in the rear for a more balanced setup (or to get a particular tire compound only offered in this size). It is important to note that to properly clear the front 265 you will need aftermarket camber plates with a minimum of -2.5º of camber. Depending on the tire compound you choose it is not uncommon to need to run -3º of camber up front. Not only will this provide you with the clearance needed, it will also dramatically improve handling and extend the life of your tires. If you are not interested in purchasing and installing aftermarket camber plates and you are willing to give up some front end grip, 255/35-19s are a direct fit with the factory suspension.
If your GT4 is equipped with PCCBs then a 20" setup would be necessary, This would look something like:
Front: 20x9" ET50 // Rear: 20x11" ET50
the most common tires sizes match the OE tire sizes of 245/35-20 front, 295/30-20 rear allowing you to run the OE Cup 2 or a Hoosier R7.
If you have any further questions or wish to discuss your car in particular feel free to shoot us a PM and we can help you out!
- Brandon
APEX Wheels - expert@apexwheels.com
Website - Blog - Instagram - Porsche Fitment Guides
