265/305 Supercar 3R on 718 GT4
Hey folks, anyone here happen to run 265/305 Supercar 3R tires on 19" (Apex SM10) wheels on the 718 GT4?
It's supposed to fit well with an aggressive alignment. I have them on my car with -3/-2.5 front/rear camber and 9 degree caster and they rub quite a bit at track speeds (required camber plates and toe links to get this alignment).
I'm curious if anyone is running these without rubbing and if so what you had to do to get them there.
That's odd. I ran those at the tail end of the season (on a set a Titan-7 wheels, though) and didn't have any issues with rubbing. I did have some rubbing on the rear inner fender wells with Nankang AR-1s on SM-10s. My settings aren't even as aggressive as yours: front camber is -2.7 with zero toe, rear camber is -2.2 with 4.4 total toe. I'm running the stock ride height, though; did you drop your car a bit?
JPLepak (12-29-2021)
The following 2 users liked this post by sobiloff:
JPLepak (01-06-2022),
VoodooUomo (12-08-2021)
