Run Track Wheels w/o TPMC?
Last HPDE of 2018 I hit the front of the corner curb on the track and bent my OEM rim. I had it fixed, but I’m not willing to run on the track with it; not to mention the tire may be damaged internally, too, I am going to purchase 18” wheels and tires (DOT) for HPDE’s - less expensive than 19”. Since they will be for track days only, other than travel to and from, I don’t feel like paying for TPMC units for them. Anyone else do the same?
Matt
Matt
I bought them for my track wheels. I came from an M3 that didn't have TPMS, and I have to say knowing the tire pressure over the course of the session is awesome. I would definitely recommend. I found OEM TMPS on ebay for a great price.
If you can...use TPMS on the track. It may not be precise but if you have a puncture TPMS will let you know before there's too little air in the tire to keep the shiny side up.....I use it on my GT4 on track days to keep an eye on my pressures all the time as I don't have a crew to take pressure or temps on pit lane.
I do have a pressure gauge, and check tire pressures after each run. I look at the sidewall markings and adjust pressure as needed. Most of the time my TPMC’s show errors because the pressures are so low. If I did get them, I wonder if they would simply go into error with low pressures and not be worth having.
I'm an old guy and old school, not a fan of TPMS
I have a track Vette and a street Vette, I was able to electronically delete the TPMS on those 2 cars.
I have 2 SUV's, and as TPMS failed I replaced with regular old fashioned valves and put a piece of electrical tape over the blinking red light on my dash
Have a Caddy CTS, right now have winter tires on and did not reprogram TPMS, each time I start it up I press a button on dash that shuts off TPMS warning
Got a Spec Miata, No ABS, No Stability Management let alone no TPMS
My other few cars did not come with TPMS.
My Cayman's track tires have no TPMS
Each of my cars has a tire guage and I know how to use it
As I said, I'm an old guy with old habits, don't like relying on electronics that can fail or give false readings.
Right now I'm using a computer with XP
I don't like fixing what ain't broke
But that's me, just an old guy set in his ways with a bunch of tire guages and Windows XP
TPMS is not needed for track wheels. Usually not accurate enough in any case. I check pressure and wheels after EACH session. It a safety thing for me since I check mor3 than just pressures. My .02$
Exactly my thought! I have a good pressure gauge and check pressures after each run, so I’m going with no TPMS on the track set.
