Wheel and Tire Forum
BBS E88 with NT01
Old 10-22-2018, 07:34 PM
matt33
matt33's Avatar
Default Solved: BBS E88 with NT01
Because the NT01 is not directional, this is apparently ok to do.
—————-_
Is it ok to swap the left and right wheel? (move the left wheet+tire to the right side/etc)
I cant see any issue.. but wanted to ask the experts before doing so. I drive on a track that wears the right side much faster than the left)
Matty
Old 11-01-2018, 02:09 PM
haulinkraut
haulinkraut's Avatar
—————-_
Matty
So your right tire wears more than the left? Are you racing circle track? Typically insides wear faster than outsides. I have swapped left for right to even tire wear before with issue. But, I had plenty of tire life left.
Old 11-03-2018, 09:22 AM
matt33
matt33's Avatar
Not a circle, but a track with lots of long fast left handers so the right side wears much faster.
Heard from others who rotate wheels in this way all the time no problem. I think flipping the tires on the rim is questionable for most tires though due not just to tread patterns, but potential sidewalk differences inside vs out.
Quick Reply: BBS E88 with NT01
