Just looked at the difference brake calipers are often overlooked. But they are an important component of your vehicle's appearance. Most vehicles come with unpainted calipers from the manufacturer and most of the time are cast metal and tend to become rusty. A coat of paint makes the caliper look good and protects it against corrosion and it also makes it easier to keep clean. The brake calipers are not removed from the car to carry out the painting process, as this would require disconnecting and disturbing hydraulic brake lines and would require bleeding of the system, which would add considerable additional time and expense to the process. Removing the calipers would also create a safety issue with the antilock brake system.
Contact us to get more information or visit our website: 📧 EMAIL: info@mumsports.com 📞 CALL (510) 510-462-3797
