Recently, here at the 4WheelSpacers headquarters, we had a 2023 Porsche Cayenne Turbo GT come in the shop for lowering and had the chance to test some of our own spacer setups on it.
The goal was to achieve the closest possible fitment to the fender without poking past, in other words, a FLUSH look. In addition, the newly equipped set of lowering links allows for an even lower ride height which helps the gorgeous 22" GT Design wheels stand out more.
We managed to find the right setup to achieve that flush and aggressive look without having any sort of rubbing issue whatsoever.
Furthermore, our Hub-Centric spacer lineup for this platform is specifically designed to fit the new 5 Tab wheel hubs equipped on these vehicles and the new 911(992) seamlessly for a vibration and hassle-free fit.
Here you will find pictures of the 2023 Porsche Cayenne Turbo GT fitted with the Porsche GT Design wheels in 22x10J ET48 with our own set of 12mm spacerson the front and 22x11.5J ET52 with 10mm spacers in the back.
GET 10% OFF YOUR ORDER WITH COUPON CODE: "GT10" ON OUR WEBSITE AT CHECKOUT!
2023 Cayenne Turbo GT with 4WheelSpacers Hub-Centric Wheel Spacer Kits.
4WheelSpacers 12mm Hub-Centric Wheel Spacer Kit on front hub of 2023 Cayenne Turbo GT.
4WheelSpacers 10mm Hub-Centric Wheel Spacer Kit on rear hub of 2023 Cayenne Turbo GT.
4WheelSpacers Hub-Centric Wheel Spacer Kit on 2023 Cayenne Turbo GT.
2023 Cayenne Turbo GT with 4WheelSpacers 12mm Hub-Centric Wheel Spacer Kit on front hub.
2023 Cayenne Turbo GT with 4WheelSpacers 10mm Hub-Centric Wheel Spacer Kit on rear hub.
4WheelSpacers Your #1 Source For The Best European Wheel Spacers and Adapters -SUMMER SALE ON LOTS OF PRODUCTS - QUALITY HUB CENTRIC WHEEL SPACER KITS FOR AUDI, BMW, MBZ, PORSCHE, VW 5MM UP TO 40MM !!! EMAIL: INFO@4WHEELSPACERS.COM WEBSITE: WWW.4WHEELSPACERS.COM
