Vendor Announcements A place for Rennlist Sponsors to post new products, sales, and deals for members.
NEW PRODUCT ALERT | AIM Shift Light Module
Old 12-20-2018, 12:12 PM
Stable Energies
Former Vendor
Stable Energies's Avatar
Default NEW PRODUCT ALERT | AIM Shift Light Module
Available now - AIM Sports Data's new Shift Light Module $189.00
Shop Here
Shift Light Module
Your shift lights where you wish
The Shift Light Module is a compact array of ten RGB LEDs which help monitoring RPM thresholds, alerts and other indicators.
It can be helpful when you have a logger but not a dash, or even in case your dash is positioned where you can't easily see its shift lights.
Versatile Configuration
With the Race Studio 3 software you can easily set the LED color and the RPM value that turns each LED on/off, also in dependance upon the gear number. It is fully customisable: users can select a solid alarm or flashing one - and its flashing frequency - choose to have a warning message, and also set the alarm priorities.
You can set the Shift Lights Module as a Predictive Lap Timer as well:
The LEDs bar will turn green if you are improving your chrono
compared to the best one of the session or instead they will turn
red if you are getting worse.
The Shift Light Module is CAN compatible with the following AiM systems:
  • EVO4S
  • EVO5
  • MXL2
  • MXG
  • MXG 1.2
  • MXG 1.2 Strada
  • MXP
  • MXP Strada
  • MXS
  • MXS 1.2
  • MXS 1.2 Strada
The Shift Light Module does not come with any wiring, be sure to pick up a Shift Light Module Patch Cable HERE
Any questions let us know here or call us at (973) 773-3177 and ask for Carlos.
Front View w/ Lighting options
Rear view with cable connection
Side profile
Packaging
Stable Energies is offline
Quick Reply: NEW PRODUCT ALERT | AIM Shift Light Module
