Mark this thread as Unsold
Boxster S Race Car with Audi 4.2 V8 engine and LOTS of MoTec
Year: 2000
Make: Porsche
Model: Boxster
Mileage (numbers only please): 1000
Color: Green
VIN: WP0CB298XYU661289
Price (no $ sign please): $39999
Private or Dealer Listing: Private Listing
Location (Region): West
Body Style: Coupe
Transmission Type: Manual - 6 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: None
The car has a NASA logbook, but with the cage and safety equipment it has, it would also be legal for competition use with SCCA, PCA, POC and BMWCCA.
The entire build and rebuild was very well documented, so if there are more pictures that you would like to see, chances are I've got anything it.
Exterior
- Fiberglass, light weight OEM style hard top
- Quarter panels and rear wheels modified for wheel travel and fiberglass flares bonded and molded into the quarter panels and rear bumper.
- Fiberglass front fenders (late style 996 headlights) that are 1” wider on each side.
- Fiberglass GT2 style front bumper (also wider to match the fenders) that was modified so a completely flat splitter could be mounted to it with integrated brake ducts.
- Custom radiator ducts fabricated to allows the stock 986 side radiators to work with the GT2 radiator openings.
- Custom fabricated aluminum center radiator with ducting for additional cooling capacity.
- Carbon fiber wing (PTG design) with chassis mounted uprights.
- Gutted steel doors
- AeroCatch latches in hood and deck lid
- F1 style convex door mirrors
Interior/chassis
- TIG welded, 6 point cage with NASCAR style door bars on driver’s side
- Complete air jack system using Goodrich fittings and hard line, AP Racing inlet port, AP Racing “lance” with hose and nitrogen regulator, and KSport jacks (which could be replaced with AP Racing air jacks at additional cost)
- 987 engine cover (top) modified for intake manifold clearance.
- Dash gutted and trimmed for weight reduction
- Carbon fiber dash panels for passenger side air bag cover, center dash panel, steering wheel button panel, and gauge cluster fill.
- Custom seat mounting system on driver’s side
- Racetech RT9119HR carbon/Kevlar seat installed mid-2016 ($4000 retail)
- Custom fabricated seat back brace mounting system
- Racetech Magnum 6-point HANS harnesses installed mid-2016 (FIA cert good through 2021)
- New IO Port window net installed mid-2016
- Rennline steering wheel disconnect with OMP adapter hub
- Momo MOD30 steering wheel installed mid-2016
- Rennline shifter raiser (7”)
- Safecraft 10lb Halon fire suppression system with two nozzles in engine bay, one in cockpit, and one in front trunk
- Custom built throttle pedal system (Cup style)
- Custom pedal overlays for brake and clutch pedals, and flat floor panel for driver’s side footwell
- Custom billet aluminum interior door pull/release (drivers side) and looped cable pull (passenger side)
- Panel/wink style rear view mirror (center)
- Steering wheel hook
- 24qt. Cool Shirt system with air provisions (which can be plumbed into the port in the back of the seat, or into a helmet air port if desired.
- High density cage padding in required areas
- Retractable Cup style tow hooks front and rear
Electronics
- MoTec M880 ECU with logging (multi-tune 4 position rotary switch)
- MoTec C125 dash with logging
- MoTec PDM30 (chassis power distribution)
- RaceGrade 15 and 8 button panels control panels
- Motorola PM300 radio system with low profile antenna (with matching CP200 hand helds and crew radio headset)
- Odyssey PC950 battery with Anderson Power Clip
- Custom master power disconnect system with dual activation switches (interior and exterior)
- Wired AMB transponder (original style not the new subscription based system)
- Electronic power steering pump (Denzo/Toyota based)
- AiM SmartyCam HD camera
- Complete, custom MIL spec chassis wiring harness and engine management harness
- Original Boxster ABS system
Fuel system
- Dual Bosch 044 fuel pumps with Radium distribution block
- Aeromotive fuel pressure regulator
- Aeromotive fuel filter
- Custom built swirl pot (supplied by OEM in-tank fuel pump)
- Custom billet aluminum fuel rails (plumbed in parallel)
- Fuel system plumbed using hard anodized fittings (XRP fittings when possible) and Prolite-Ultra hose.
- New fuel injectors (Ford Motorsports)
- Staubli quick disconnect plumbed inline for easy fuel pump-out (includes pump-out line)
Brake system/Wheels
- Boxster S brakes with Pagid pads (front pads are brand new)
- Porsche Motorsports, 997 Cup dual master cylinder set-up with Tilton 76 series master cylinders and Tilton remote bias adjuster (cockpit adjustable)
- Recently replaced stainless steel braided lines and fresh Motul RBF600 brake fluid
- GT3 front brake ducts
- CCW Classic wheels (peened) with GM style lug nut seats. Sizes are 17”x12” rear, 17’x10” front. Typically the car runs 315mm wide tires rear, and either 275mm or 295mm wide fronts depending on tire brand used and desired vehicle balance.
Drivetrain
- Audi ABZ 4.2 liter V8 engine (85K miles) with exceptional leak down numbers. New timing belt kit, new water pump, new valve cover seals, new spark plugs, new cam seals, and custom modified oil filter housing for remote oil filter and Accusump.
- Custom engine mounting system that bolts into existing chassis provisions
- New starter motor
- Custom stainless steel headers with Burns Stainless collectors, and custom stainless steel exhaust system (987 style routing) with v-band disconnect. All stainless steel welds are fully back purged
- Custom fabricated intake manifold using GM LS1 throttle body and custom fabricated intake system (with heat shield)
- Low mileage 987 6 speed transaxle with Drexler LSD (uses standard length 987 shifter cables)
- 034 Motorsports flywheel insert with Southbend clutch (no adapter plate needed between engine and transaxle)
- New clutch slave cylinder
- Trunk mounted engine oil cooler (Setrab) with cooling fans (Spal)
- Transmission oil cooler (Setrab) mounted in quarter panel duct, with Mocal heavy duty fluid pump.
- 3 quart Accusump system (electric)
- Custom catch can system (trunk mounted catch can)
- New OEM 986 expansion tank and cap
- Engine oil and transmission fluid system plumbed using hard anodized fittings (XRP fittings when possible) and Prolite-Ultra hose
Suspension
- Tarett Engineering control arm monoballs
- Tarett Engineering control arm thrust bushings
- GT3 front sway bar with Tarett Engineering “GT3 extended” drop links
- Tarett Engineering bladed rear sway and drop links with cockpit adjustment.
- Tarett Engineering rear top links
- KSport shocks, springs and camber plates
Basic Site Sponsor
Basic Site Sponsor
Received 2,844 Likes
That's pretty darned cool! And looks very sanitary!
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Wow! Well done. Sounds like a beast. GLWS!
Wow, that thing is bad ***!
However the startup video reminded a little of this scene:
