Mark this thread as Unsold
Supercharged Honda s2000 time attack record holder
Year: 2000
Make: Honda
Model: S2000
Mileage (numbers only please): 600
Color: Orange
Price (no $ sign please): $28000
Private or Dealer Listing: Private Listing
Location (Region): SoCAl
Body Style: Speedster
Transmission Type: Manual - 6 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM Radio
Means of Contact: PM or email, dom.kouki@gmail.com
Background:
That car that you told yourself, "i am going to do everything right." This is the Autofunction "Orange Crush" s2000.
Knowing that every part of a car has been built, assembled, and tested is where real piece of mind lies. All parts, minus the brake kit are new and have under 30 hours of use. 600 miles of driving around town, including being driven to the track, then driving it on the track and back home have been put on it without hiccup. All seals, hoses, weatherstripping, fluids and parts have been touched and started life at the beginning of the cars build.
The car can be sold with an array of options and will cost anywhere from 28k to 35k (meaning the way the car sits) depending on what the car will come with, For real inquiries please contact me via email, dom.kouki@gmail.com
Suspension/Drivetrain:
KW Clubsport dampers
Kaaz 1.5 way differential
Kingpin FULL spherical bushing kit
Wicked tuning front out tie rods
Buddy Club front roll center Adjuster
Front and rear Eibach sway bars
Hard Race rear toe kit
SPC rear upper adjustable ball joint
Has Sport motor mounts
Has Sport differential mounts
Engine:
F22 block Honed to 87.5 with Micropolished crank
Mahle Pistons with 12.7:1
Skunk2 Alpha rods
Factory Honda rod bearings
Freshly built head
Brian Crower valves
Brian Crower Titanium retainers
Brian Crower dual valve springs
Supertech Valve guides
Honda OEM head gasket and entire head rebuilt it used in assembly
Grams 1100cc injectors
Grams 320lph fuel pump
Grams 3 bar map sensor
Russel fuel pressure gauge
Kraftswerk Super charger system
Kraftswerk intercooler system
AEM infinity ECU
AEM adapter harness
AEM O2 sensor extension kits
Koyorad radiator
Exhaust:
Skunk2 Alpha Headers
Greddy TIC Catback
Wheels/brakes:
17x9 +40 Volk SE37K
17x9.5 +40 volk se37k
Willwood superlite 6 pot front big brake kit
Stainless braided lines on all 4 corners
Interior/safety:
Recaro Pole position Driver seat
Sabelt 6-point hans compatible harness, expires 2019
Pro Car Innovations seat base kit
Works bell steering hub
NRG quick release
Momo Steering wheel
Rockstar garage roll bar
Battery relocation kit (trunk)
Aluminum sealed battery box
Exterior:
Rockstar garage double sided carbon oem style hard top.
APR GTC-250 wing, 76 inch wide version
Newly replaced windshield from when the paint was done
