Mark this thread as Unsold
FS: 1984 Carrera Cabriolet
5th Gear
Year: 1984
Make: Porsche
Model: 911
Cont. Porsche Models: 911
Mileage (numbers only please): 170000
Color: Guards Red
Price (no $ sign please): $12000
Private or Dealer Listing: Private Listing
Location (Region): NorCal
Body Style: Cabriolet
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM CD
Currently, the car has 170k miles and been regularly maintained. Last year, I began a major suspension, transmission, and brake upgrade/refresh. I have all receipts for the car dating back to 12/1984. The car is a blast to drive on the street.
The paint and interior is original. The front seats are starting to show their age. The drivers seat has a cover on it.The top is in good shape but will probably need to be replaced within the next year.
Below is a list of all the work done on the car. All work was done about 18 months ago. Please send a PM with any other questions you may have. Thanks for your time!
Transmission Work:
Transmission rebuilt by Mobile Works West (Synchros, Dog Teeth, Bearings)
New throw-out bearing, clutch fork, clutch cable, WEVO shift coupler
Factory short shift kit
All new pedal and shift bushings
Poly-Graphite Transmission Mounts
New axles
Suspension Work:
Elephant Racing rubber bushings (Control Arms, Camber Plate, Sway Bars)
Elephant Racing trailing arm bushings
New Ball Joints
Bilstein HD inserts
21mm/28mm solid torsion bars
Turbo Tie Rod kit
Bump Steer kit
Car has been professionally corner-balanced and aligned.
Brake & wheel work:
New brake rotors (front and rear)
Rebuilt brake calipers
New front and rear wheel bearings
Brake fluid flush
Engine work:
Replaced engine gaskets
Re-sealed intake manifold
Magnacore 8.5mm wires
New Fuel Injectors
Steve Wong Chip
Flowmaster 1 in 2 out muffler (also have the original muffler)
Poly-Graphite Engine Mounts
Misc:
Momo steering wheel (also have the original wheel)
H4 headlight upgrade with relay kit
Wheels refinished by Al Reed
Backdated heat
