Vehicle Marketplace - Old A place for Rennlist Members & Sponsors to sell their new & used vehicles.
Mark this thread as Unsold
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Mileage (numbers only please):
Color:
Price (no $ sign please):
Private or Dealer Listing:
Location (Region):
Transmission Type:
Parts Search
Keyword:
Category:
Private or Vendor Listing:
Location (Region):
Item Condition:
1987 M491 Cabriolet
Old 03-05-2018, 04:11 PM
TJsBeer
TJsBeer's Avatar
Default 1987 M491 Cabriolet
Year: 1987
Make: Porsche
Model: 911
Mileage (numbers only please): 99382
Options (Please check ALL which apply): Air Conditioning, Cruise Control, Foglamps, Intermittent Wipers, Leather Seats, Power Door Locks, Power Windows
Color: Venetian Blue
VIN: WP0EB0911HS170749
Price (no $ sign please): $69000
Private or Dealer Listing: Private Listing
Location (Region): NorthEast
Body Style: Cabriolet
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM CD
1987 Porsche 911 M491 Cabriolet (Very Rare Find; 1 of 303)
3.2 Carrera; G50 transmission
Venetian Blue over Champagne
VIN WP0EB0911HS170749
Factory option codes:
018 - Sports Steering Wheel with Elevated Hub
158 - Blaupunkt Reno Radio
341 - Central Locking
439 - Electric Cabriolet Top
454 - Automatic Speed Control
491 - Turbo Look, includes:
  • Factory wide body
  • Front & rear spoilers
  • Turbo brakes
  • Turbo suspension
533 - Alarm System
Original engine and trans with 99,382 miles (as of 3/7/18)
Fully functioning Electric Cabriolet Top with Clear Rear Window
Original service book, warranty book, tools, jack, COA, window sticker
Porsche spare tire air compressor
Convertible top boot
Blaupunkt Toronto BT head unit installed by PO (I have the original head unit)
Fabspeed high flow cat and max flow muffler (12/2017; I have the original cat and muffler)
All body vin tags, drivetrain tags and stickers in place
Owned by long-term PCA Member (Riesentöter Region)
Stored in climate controlled and insulated garage
Compression & Leak Down Results
Cylinder 1: 160 6%
Cylinder 2: 160 6%
Cylinder 3: 163 3%
Cylinder 4: 162 4%
Cylinder 5: 160 5%
Cylinder 6: 160 5%
Tires: Bridgestone Potenza RE-11s
Front: 225/50R16 date code 0417
Rear: 245/45R16 date code 0416
Recent Engine Out Service by Performance Auto in Malvern, PA at 98,669 miles
  • Inspected head studs and re-torque head
  • New clutch, clutch fork, shaft bearings, pilot bearing, flywheel ring gear, release bearing, lever shaft & lever shaft seal
  • New slave cylinder & slave cylinder line
  • New input shaft seal
  • New rear main crankshaft seal
  • New intake manifold gaskets
  • New oil lines
  • New fuel lines
  • New breather hoses
  • New cooling fan pulley
  • Valve adjustment
  • New valve cover gaskets
  • New spark plugs and ignition wires
  • Fuel injectors cleaned
  • Mobil 1 20W-50 oil & new oil filter
  • Mobil 1 gear oil
  • New shifter bushings & pivot cup
  • A/C conversion from R12 to R134A with new o-rings & fittings
  • New A/C receiver drier
  • New O2 sensor
  • Sent ECU out to be re-built
  • New luggage compartment struts
  • New engine compartment struts and deck lid latch
  • Replace K&N air box with stock air box and new air filter
  • Rebuilt starter
  • New Interstate battery
  • New OEM match champagne carpets from Lakewell
  • New Lloyd floor mats
  • New frunk carpet set from Auto Atlanta (have the original perlon)
  • Front seats reupholstered by PO
  • Very high quality repaint by PO
  • No chips, dings or scratches
  • All electrics and mechanicals operate properly with exception of the cruise control
Photo Album:
https://photos.app.goo.gl/rbg79lheXoX0XT8b2
Cold Start Video (42 degrees outside):
Cold Start (Single digit temperatures outside):
Drive Off Video (Single digit temperatures outside):
Walk Around Video:
Power Top Operating:
Photo Album:
Ownership History:
1st Owner - Richardson, Texas
(Service records from new until 1991)
2nd Owner - Flower Mound, Texas - 1/29/1992, 33,675 miles
(Two service records from 1997)
3rd Owner - Dallas, Texas - 5/10/2001 approximately 88,000 miles
(Two service records from 2004 & 2005)
4th Owner - Charlotte, North Carolina - 11/4/2005, 93,484 miles (No service records)
10/5/2011 - “Very Minor rear end damage reported”; I was told by the consignor that the 911 was scratched on the rear decklid while parked, requiring the rear decklid to be repainted.
5th and current owner - Valley Forge, PA - 6/13/2017, 98,618 miles
TJsBeer is offline
Old 03-05-2018, 08:05 PM
hlee96
hlee96's Avatar
Beautiful car! You're leaving alot of money on the table with this one! Just build another garage. Ask me how I know....
How about selling that 308? I will help you my friend.
-Hoi
hlee96 is offline
Old 03-05-2018, 08:35 PM
TJsBeer
TJsBeer's Avatar
-Hoi
You'll have to negotiate with my widow Hoi. It's the one I car I will never sell.
TJsBeer is offline
Old 03-05-2018, 09:23 PM
RadDoc24
RadDoc24's Avatar
who did you get to redo that interior on the 308? looks great!!!
RadDoc24 is offline
Old 03-06-2018, 07:47 AM
TJsBeer
TJsBeer's Avatar
My 308s interior is original.
But, I think you might be referring to the photo in my signature which is the Pasha interior of the '78 928 I recently purchased.
Bob Budd of Classic9 Leather Shop did the interior on that one.
TJsBeer is offline
Old 03-06-2018, 07:50 AM
TJsBeer
TJsBeer's Avatar
Not sure why, but I can't get the walk around video to load in the original ad.
TJsBeer is offline
Old 03-06-2018, 12:55 PM
JLG
JLG's Avatar
Your ad should be used as a template for all the moronic sellers who put no detailed info into their ad yet expect top $$$
JLG is offline
Old 03-06-2018, 02:17 PM
TJsBeer
TJsBeer's Avatar
Talking
HA!
Thank you.
I try to give all the information I would want when purchasing a car without a lot of filler.
TJsBeer is offline
Old 03-12-2018, 02:49 PM
TJsBeer
TJsBeer's Avatar
Sold.
Thank you Rennlist
TJsBeer is offline
Quick Reply: 1987 M491 Cabriolet
