Mark this thread as Unsold
1993 Porsche 968 - 122K Miles - Liquid Copper
Year: 1993
Make: Porsche
Model: 0
Cont. Porsche Models: 968
Mileage (numbers only please): 122500
Options (Please check ALL which apply): Airbags, Air Conditioning, Alarm System, Antilock Brakes, Cruise Control, Foglamps, Intermittent Wipers, Leather Seats, Power Brakes, Power Door Locks, Power Steering, Power Windows, Sunroof
Color: Slate Grey - Liquid Copper Vinyl Wrap
VIN: WP0AA2961PS820574
Price (no $ sign please): $12000
Private or Dealer Listing: Private Listing
Location (Region): Midwestern
Body Style: Coupe
Transmission Type: Manual - 6 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM CD
Year: 1993
Make: Porsche
Model: 968
Mileage: 122500
Color: Slate Grey (Factory) - Liquid Copper (Vinyl Wrap)
Engine: 3.0 Liter 4- Cylinder
Transmission: 6-Speed Manual
Drivetrain: Rear Wheel Drive
Maintenance: (I have records back to 3-1-2001 • 76,000 miles)
Clutch & 83,075
AC Compressor Line Seals & AC charge @ 99,944
Fuel Sending Unit @ 103,228
Thermostat @ 105,134
Valve Cover Gasket @ 109,469
Coolant Temp Sensor Fan @ 110,170
New Slave Hose Master - Clutch Hydrolics @ 118,487
Timing Belt @ 118,487
Oil Pan Gasket- 121,000
Full Synthetic Oil Change (Motul 4100 Synthetic 15W50 engine oil) - 121,000
New Parts Installed:
Rear Bumper Trim
Front Bumper Right Trim (Under Headlight)
Front Bumper Left Trim (Under Headlight)
Outer Door Handle Seal Small Left
Outer Door Handle Seal Small Right
Outer Door Handle Seal Large Left
Outer Door Handle Seal Large Right
Cover Strip For Rocker Panel Short Left
Cover Strip For Rocker Panel Short Right
Cover Strip For Rocker Panel Long Left
Cover Strip For Rocker Panel Long Right
Outside Mirror Base Gasket Left
Outside Mirror Base Gasket Right
Rocker Panel Clip x 2
Porsche Hood Crest
Modifications:
3M 1080 Liquid Copper Full Paint Wrap done @ Creative Color Studio
968 Club Sport Center Tray Replacement
Black Interior Swap (Original included)
17" Turbo Twist Wheels
*Clean and Clear MN title
Make: Porsche
Model: 968
Mileage: 122500
Clutch & 83,075
Rear Bumper Trim
Porsche Hood Crest
Modifications:
*PPI Inspection was just completed recently for the sale
*No prior accidents are indicated on the included Carfax
*Additional receipts and records for parts and service date back to March 2001
*The original Grey interior and a Porsche protective front-bra are included with the sale
I purchased the car from European Imports in PA July of 2016. Previous owner was a long term client of European Imports where I bought it from. (I have records back to 2001 @ 76K miles). Creative Color Studio vinyl wrapped the car in Nov of 2016. All new exterior rubber gaskets, seals (minus window molding) and new hood emblem were replaced at the same time. This spring I noticed an oil leak - ended up being the oil pan gasket which I had replaced. Car now has no oil leaks. A full synthetic oil change was preformed at the same time. May of 2017 I installed black seats out of a 1991 S2 944. I purchased the interior from Plyhammer's Parts. (Original grey interior parts and Porsche front bra also included.) Car runs and drives great! AC is ice cold. CD and radio work great. Everything works great except the passengers door (only from the outside) doesn't work. This stopped working recently. It does work from opening from the inside of the car. Couple other things, the dashboard has the classic 944/968 cracking, shift **** is a bit worn too. Car also comes with original 968 owners manual and 3 sets of keys. One key is brand new that has the working LED light when you push the button.
The original paint shows well for a 25 year old car, but it did have a couple blemishes on the hood and a little clear coat peeling on the rear bumper. I had those spots sanded, repaired and primed before having the car wrapped. I didn't have those two areas re-sprayed the original Slate Grey as I wanted to wrap the car a bright color. The vinyl not only makes the car look new on the outside, but it also protects the original paint underneath it.
Creative Color in Minneapolis, MN wrapped the car. They are a 3M certified shop. The vinyl wrap can easily be removed, would take 2-4 hours. The original interior is also included so the car could be brought back to stock if the new owner ever wanted in the future.
This is a driver's car that looks and drives great! This is a well maintained 968 with the expensive services already done. The service history, car fax and PPI reflect that.
I have MANY more photos (including pics before the car was wrapped and under body photos, PDF of all the maintenance records I have for it. Carfax report and PPI report.) If interested in the car, please contact me and I can email you everything.
*Selling as I've purchased my next car project. Not enough room to keep both.
VIDEO Walkaround:
MANY more photos available.
Questions: Call / Email / Text
Asking $12,000
Listed on ebay: - EBAY LINK:
