Mark this thread as Unsold
2007 Cayman - Track Day Ready!
Year: 2007
Make: Porsche
Model: Cayman
Mileage (numbers only please): 36350
Options (Please check ALL which apply): Airbags, Air Conditioning, Alarm System, Antilock Brakes, Cruise Control, Foglamps, Intermittent Wipers, Power Brakes, Power Door Locks, Power Steering, Power Windows, Traction Control
Color: Silver
VIN: WP0AA29887U761030
Price (no $ sign please): $24000
Private or Dealer Listing: Private Listing
Location (Region): SouthEast
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM CD
I took over the car in March 2015 and only put about 3000 more street miles on it. It's the perfect car for someone who wants to go to and from the track without a trailer or blast some back roads. I just do not have the time to enjoy it as intended.
I have all docs and records of everything done. His maintenance and care for the car was also over the top and I followed suit. I'm happy to answer any questions. Below is a partial list of mods and maintenance. No second set of wheels/tires.
I'm a asking $24,000. Clear title in hand. Car is in Atlanta. Post here, PM, or email erikvanname_at_gmail.com
-DE Prepped 2007 Cayman Base 2.7L, 5 speed
-Silver/Gray
-I'm third owner (father was second, bought it off lease in DC)
-No accidents or stories
-Paint is great with one small scratch on passenger side rocker
panel.Has clear bra on front
-Interior is good with normal wear for this era 987
-18" S wheels with Michelin Pilots (80% left, no track)
-Heated seats, auto climate control
Mods include:
-Vision Motorsports front BBK/GT3 6 piston calipers & 350mm AP slotted rotors
-FVD deep sump oil pan
-TTP oil scavenge pump
-987 Motorsport AOS
-Softronics SRPicon & 4.1 flash
-Cayman R struts/springs
-TPC sway bars
-RSS front and rear LCAs
-Tarett bump steer toe links/drop links/front camber plates/rear strut mounts
-GT3 Master Cylinder
-3 QT Accusump in tunnel
-3 CSF Aluminum radiators
-GSR electric PS pump kit
-Fabspeed headers/sport cats/Maxflow exhaust
-CAE Ultrashifter
-996 oil cooler and swirl pots
-Rennline gas pedal
-Odessy AGM battery
-BBi sport coil packs
-luggage barrier
-Wheel studs
-Fire extinguisher
-Technobrace
-Rennline tie downs
-Technotooth Bluetooth module
-Oil pressure and temp guages
Maintenance State at mileage 36350 10/14/17:
REPLACE HEADLINER 35959
DT40 OIL+FILTER, BRAKE FLUSH, CLUTCH BLEED 35939
DT40 OIL+FILTER 34577
DT40 OIL+FILTER 32697
REPLACE COOLANT 30973
REPLACE BRAKE FLUID 31847
REPLACE WIPER BLADES 29178
REPLACE TRANS AXLE FLUID 31847
REPLACE PS FLUID 29837
REPLACE ENGINE AIR FILTER 32006
REPLACE CABIN AIR FILTER 29178
WHEEL ALIGNMENT 30800
WAX 30314
REPLACE DRIVE BELT 29837
REPLACE TPMS 32855
REPLACE SPARK PLUGS 32045
REPLACE MANY COOLANT HOSES 23447
REPLACE FRONT TIRES 25847
REPLACE REAR TIRES 30392
REPLACE BATTERY 20700
REPLACE WATER PUMP 25123
REPLACE THERMOSTAT 21857
REPLACE COIL PACKS 27003
REPLACE HEADERS/SPORT CATS 27179
REPLACE AIR OIL SEP/MOTOR SPT 22870
SOFTRONICS PLENUM & FLASH 22870
REPLACE FRONT BRAKE PADS 29388
CLEAN MAF 32770
REPLACE RIGHT REAR TIRE 32855
REPLACE THREE RADIATORS/CSF 30973
Nicely prepped Cayman
I promised the wife I'd hold off until the new year. If you don't sell it by then, look me up on RL.
Certainly should sell to the right person before that, though!
Regards,
Erik
Received 2,012 Likes
PM sent. give me a call please.
