Mark this thread as Unsold
1982 Porsche 928
Cruisin'
1982 Porsche 928
Year: 1982
Make: Porsche
Model: 0
Cont. Porsche Models: 928 (all)
Mileage (numbers only please): 127000
Color: Rosewood metallic
Price (no $ sign please): $6500
Private or Dealer Listing: Private Listing
Location (Region): NorCal
Body Style: Coupe
Transmission Type: Tiptronic
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM Cassette
Interior is cork, and very presentable as is. It has its share of heat exposure (dash shrinkage, faded carpet) but the fronts were recovered apparently very recently (no receipts, but they look fresh). The rears look original (not as supple, but surprisingly still good, no rips), and do not look out of place compared to the fronts.
The passenger window does not go down. All other functions seem to work, but the speedometer/odometer stopped working recently.
Recent service (receipts available):
January 5, 2017 at Kendall in Bend, OR totaling $9755.83:
multi-point inspection
wiper blades
L/F fender liner
R/F fender liner
replaced steering rack boots
removed steering rack and replaced rack bushings
adjusted front wheel bearing endplay
replaced front and rear brake hoses and flushed/bled system
replaced alternator cooling hose
replaced front valence and intake ducts
replaced L/F control arm
replaced R/F control arm
replaced oil pan gasket with silicone gasket
oil and filter change
replaced engine mount struts
replaced L cam end cap gasket
replaced timing belt
replaced water pump
replaced v-belts
replaced thermostat
replaced tensioner
filled/bled cooling system
replaced air cleaner straps
4 wheel alignment
replaced L/F upper ball joint
replaced O2 sensor
April 13, 2017 at Peter's Imports Car Service in Vancouver, WA totaling $1487.46
installed good used transmission (bought from Gundie's in Vancouver, WA on 4/4/17 for $433.60)
I bought this car in May 2017 and drove it 10 hours from Washington to California. One month later I bought another 928 and now must sell one. I'm motivated but will respond selectively. Car is still registered in OR but is currently in Elk Grove, CA.
E-mail for more pictures and information.
Paint color is rosewood metallic (I think, haven't found the paint code but seems correct for year). It had a partial respray prior to me. The worst defects are small rust at the bottom of one rear window, a couple shallow dents, some isolated clear coat issues. It is a driver. I'm generally very picky, but the car is what it is, and I like it for what it is. My plan was for it to be a driving restoration/project with a total respray at the very end.
wiper blades
L/F fender liner
R/F fender liner
replaced water pump
replaced v-belts
replaced thermostat
replaced tensioner
4 wheel alignment
replaced O2 sensor
wiper blades
L/F fender liner
R/F fender liner
replaced water pump
replaced v-belts
replaced thermostat
replaced tensioner
4 wheel alignment
replaced O2 sensor
