Vehicle Marketplace - Old A place for Rennlist Members & Sponsors to sell their new & used vehicles.
Mark this thread as Unsold
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Mileage (numbers only please):
Color:
Price (no $ sign please):
Private or Dealer Listing:
Location (Region):
Transmission Type:
Parts Search
Keyword:
Category:
Private or Vendor Listing:
Location (Region):
Item Condition:
FS: 2002 B5 s4 AWE stg3/ Stasis 4:1/ rebuilt box/ lot's of maint! Lakeland, FL $14200
Old 08-09-2012, 01:53 AM
30vQuattro
30vQuattro's Avatar
Default FS: 2002 B5 s4 AWE stg3/ Stasis 4:1/ rebuilt box/ lot's of maint! Lakeland, FL $14200
Year: 2002
Make: Audi
Model: S4
Mileage (numbers only please): 143000
Options (Please check ALL which apply): Airbags, Air Conditioning, Alarm System, Antilock Brakes, Cruise Control, Intermittent Wipers, Leather Seats, Power Brakes, Power Door Locks, Power Steering, Power Windows, Sunroof, Traction Control
Color: Santorin Blue
VIN: WAURD68D72A000917
Price (no $ sign please): $14200
Private or Dealer Listing: Private Listing
Location (Region): SouthEast
Body Style: Coupe
Transmission Type: Manual - 6 speed
2 or 4 Wheel Drive?: 4 Wheel Drive
Engine Type: Turbo
Stereo System: AM-FM CD
2002 b5 s4 sedan (last year the b5 was made/ 2.7 biturbo). Car has alot of money invested into it and If I don't get what I want out of it I'll keep it. Only reason I'm considering selling is i'd like to get into something a cheaper to free up some cash and I'll need money to continue paying for my career. Lowballs will be ignored!
It needs nothing done to it (I'm **** about mainenance), turbos don't whine (cooled down and warmed up proppertly every time), and oil changes have been done every 4-5k miles with 5w40 sythetic (royal purple, rotella, Castrol syntec, or Mobil1 used). I went with a white theme with my car, but (Except for the wheels) I have all the stock blue pr chrome parts to take it off.
It's santorin in color and let me start out by saying the car was in a fender bender. And the incident was exactly that; a low speed fender bender (in a parking lot) the P.O. was backing out of the spot and someone ran into the passenger rear quarter. It was repaired when it happened. Title is clean, I have Experian autocheck, and the database records from the state available. Here's the Vin# just in case you'd like to pull it yourself: WAURD68D72A000917.
Paint has no fade at all, but front bumper, could use a re-spray. Car has been washed ever week, and waxed every other month.
Car is currently at 141,xxx. Absolutely No rust. Has some chips on its nose, the front bumper has a crack under the drivers side headlight from bottoming out on my driveway. Nappa Leather is in fantastic condition, conditoned with leatherique (Amazing stuff if you're unfamiliar with it, just little expensive) constantly. Even drivers seat is near perfect (best I've seen on a b5 other than new). Screen in the instrument cluster is 100%. Bose sound system sounds great.
Mods/ maint:
- Off the shelf AWE Stage 3 kit at 85k
- AWE boost gauge (30 psi version with bright needle)
- Canadian Fogless bumper grilles
- AWE Aluminum pedal set
- New sport trim from Audi at 120k (not a nick on it)
hazard/ fog/esp surround
ash tray
shifter surround.
- New stock radio from Audi at 120k
- Stern snub mount at 120k
- RS4 motor and transmission mounts at 120k
- New Bilstein control arms at 120k
- New front axles at 120k
- New bosch aux water pump at 120k
- Stais SS (Koni) coilovers at 122k
- JHM short shifter at 124k
- Depo Euro headlights with OEM ballasts at 124k
- New fuel cap from Audi at 124k
- New coolant tank cap from Audi at 124k
- New headliner from Audi at 124k
- Vast downpipes with main cat's deleted (Straight pipes) at 126k
- Custom 3" exhaust with a magnaflow muffler (Sound Amazing).
- APR Bipipe, with bosch 710n dv's at 128k
- New B6 s4 nappa shift ****/ boot at 130k
- Delrin shift linkage upgrade at 133k
- New Audi N75 Valve at 133k
- Trans rebuild with updated shift collars from: http://www.advancedautomotion.com/pr...ducts_id=263at 134k
- Titan Sintofluid 75w80 gear oil for trans: http://www.advancedautomotion.com/pr...roducts_id=139 at 134k
- Clutch Masters fx400 clutch/ new flywheel/ slave cyl/ bearings with trans at 134k
- Stasis 4:1 torsen differential (splits the power 20front/ 80rear under full throttle, 50/50 under normal acceleration).
- Low temp after-run sensor at 120k (runs both aux fans, and aux water pump for a good 10 mins after car is shut off and cools everything down)
- Ngk bkr7e's at 132k
- New bosch fuel filter at 134k
- ER (Evolution Racewerks) Sidemount intercoolers. at 135k
- Evo cold air intake at 137k
- New Duracell Battery at 138k
- Forge 007 dv's at 138k (bosch 710n's leaked at full boost)
- 19" white rs6 reps, ET30 and 8.5" wide (New toyo proxes1 at 138k).
- Full timing belt kit with gates racing belt (Water pump/ crank, cam, valvecovers seals/ tensioners) at 138k
- JHM Drivetrain stabilizer at 139k (had a homebrew on the there but it just kept cracking)
- Neuspeed 19mm rear sway bar with subframe reinforcement brackets at 140k
- New beefed up rear axles one at 140k, and the other at 138k
Me:
- Memeber of Audi Club North America # 42571/ Audi/Vw enthusiast since birth
***I know i'm missing alot of stuff, I will update it as I remember***
I don't let other people drive my car, so don't expect to drive it unless I see cash. Again, I'm asking $14200. This is a very powerfull car and it needs to be driven with care. Email me if you have any questions, or if you're seriously interested in the car. I would possibly be interested in a trade, so pm me if you have something to show! They have to be manual though, not interested in an smg or automatic.
30vQuattro is offline
Old 03-17-2013, 04:21 AM
N2O
5th Gear
N2O's Avatar
Please advise contact info so can view vehicle, close deal? Live in Tampa area so could wrapthis up very soon if no issues?
My email is n4131@hotmail.com Number is 813.643.4569.
Thanks in advance,look forward to hearing from you soonest.
V/R,
Billy
N2O is offline
Quick Reply: FS: 2002 B5 s4 AWE stg3/ Stasis 4:1/ rebuilt box/ lot's of maint! Lakeland, FL $14200
