What truck to pull older gooseneck
For what it's worth, and no idea by how much, but my '13 F350 SRW 4WD definitely sits taller than our team's '12 F350 2WD, not sure how much you can tell from the photo. Maybe that will make up the difference you need??? Best of luck to you, sounds like you'll have a nice set-up once it's all said and done.
They say a picture is worth 1000 words. I should have posted this at the start..
Here it is on a rented F350 when I picked it up... Its Waaaayyyyy out of level to make this work. So much so that, unloaded, I had to disconnect the trailer brakes as it locked up the front wheels every time I touched the brakes (It didn't help that is had 6 different type of tires on it)...
For what its worth, I'm gutting it and rebuilding from the ground up..... Should be nice when I'm done, but it was very rough when I bought it....
Thanks again for all the advice... That's why I love this place... Please keep it coming...
Jeff
Jeff
Tow vehicles have a "trailer brake gain controller" for the brakes. Tweaking that will help with the lockup when empty, but most of your towing will be with the car loaded.
Check tongue weight with car loaded full in front and that may bring the truck bed down a bit.
If you are gutting it just block the axels and get longer ramps to make life easier. You also need to think about castors on the tail if you do stay with the raked setup. Not so nice to drag the tail pulling into a fuel stop. Another option is larger tires if you have the clearance.
Check the age of the tires and toss them if over 2 years old, 3 years max. DO NOT CHEAP OUT ON GETTING 1 MORE YEAR!! For sure you will find out how much it sucks to have a tire blow if you run mis matched old tires. Tread wear means nothing. Trailer tire age is everything.
So here it is..... Drumroll please
2015 F350 Dual real wheels, but 2 wheel drive (very hard to find this combo).. not mention I did not want crewcab, but needed room for the dog.... So a 2WD, DRW, extended cab, long bed, that isnt white, really is getting into unicorn territory...
But i found one!!!! and it fits perfect.... Still unfinished (no walls or cabinets yet) it has 5in of clearance with the the trailer dead level. Once finished and loaded it should squat at least another inch..
RossP (02-06-2023)
ned911 (02-15-2023)
Trucker
