Best Setup for GT4
Yes, no issues whatsoever with tongue weight. Once I loaded backwards and almost ruined my wing. Wing must be in the lowest position and then it barely goes under the tire rack. But it’s very close and I did not feel comfortable. Futura trailer is 16’.5 version.
Fredman6 (02-04-2023)
What do you use to measure tongue weight? Seems hard to believe that there's enough tongue weight with the car's motor behind the axles and no tools/wheels up front.
-Mark
-Mark
Actually that car is mid engine. For tongue weight measurements with house hold tools see the bathroom scale method described on etrailer.
U only need/want 10% in the tounge so thats what 450 lbs in that set up. Gas cans, winch and tires would probably even make it too much.
No issues with tongue weight. I have a hitch with tongue weight scale in the ball mount from Weigh Safe. This was recommended by Futura.
