Anyone need a generator slide out?
I bought this very nice and sturdy generator slide out for my trailer about 3 years ago but decided to do a different generator solution. It's been sitting in my climate controlled storage since that time.
These are made to order by Multi-Motorsports. There's not a better one on the market.
Brand new never used, in the original box.
Details below:
Multi Motorsports Generator Slide out 22" model. Aluminum construction. 500lbs capacity fully extended. Ball bearing slides with locking release levers. Brand New in box. Measures 22.25" wide x 22" deep x 4.25" tall. One of the nicest slide outs on the market. Install plywood on top, bolt your generator directly on it, or you can buy an aluminum tray from Multi Motorsports for about $100. I bought new and was going to install but came up with a different solution so I no longer need it. In original box. Includes 4 anti-vibration mounts I bought from Grainger for it that are appropriately load rated.
$400 (or best offer)
Shipping included in price to CONUS.
PM if interested.
. 500lbs
Details below:
PM if interested.
. 500lbs
Installing it should just involve drilling 4 or 6 holes through the floor of your trailer (hitting the frame) to bolt it down. If you have a lip on your trailer generator door (if installing there) and it's higher than about 2" you may need to add some spacers. Not a difficult job really.
I'm including 4 load rated anti vibration mounts from Grainger that could be used to mount your generator to the slide out. Or you can just mount plywood to the top of the slide out and set your generator on that. Multi Motorsports also sells a metal tray for this slide out that mounts on top of you wanted that solution.
Hope that answers your questions. Happy to answer more or take additional measurements if you need.
