Advice on my WDH setup - Ground clearance issues
just a data point for you. My ATC raven is 22" to the bottom of the hitch on the trailer and I have no issues scrapping the bottom of the hitch on anything but the most severe inclines. Even then, the rear tends to scrape first.
its 15" to the bottom of the frame rail on the ATC, 8" wide frame rail and the hitch sits on top, thus 22".
Trucker
Have you tried pulling that trailer with that F250 without the WDH?
I am going to bet that the WDH is unnecessary for this application and your big truck will pull the little trailer NP.
I found that my knockoff WDH also controls sway when big RVs and/or 18 wheelers, like the ones your company runs, pass me on the hiway. For someone that doesn't do this for a living, daily basis, a WDH like this is very helpful and comforting.
I am about 9K-10K fully loaded with the car, tools, extra wheels, etc etc. Should be nothing for an F-250 rated at 20K lbs if I can get the squat under control.
Originally Posted by Nickshu
Yeah as I said in my first post that is kind of where I am at. With my tongue weight when loaded the back end of the truck squats way more than I would want w/o a WDH. So a regular hitch and airbags may be the next thing to try and see how it handles on the highway and in the crosswinds we get around here pretty much all the time.
My F-250 has the high capacity tow package option (which means it's an F-350 that says F-250 on it). I agree the amount it squats with what I calculate as about 1200-1400lbs tongue weight is surprising. Well below the max tongue weight rating.
Yes I have moved things around and it does reduce tongue weight when I have wheels in the back of the trailer. That did not seem to reduce squat much but it drove much better on the highway. I have cabinetry w/ tools and stuff along with a generator cabinet and fuel in the front of the trailer which makes getting weight off the tongue more challenging. Takes quite a bit to offset it. Plus hauling mid-engined cars (SPB and GT4). I guess I could go back to a 911 that would help LOL.
Nickshu (10-07-2021)
Trucker
Is your truck an FX4? I am told that the FX4 suspension has a softer spring rate in the initial 2" of travel. That maybe the reason for the sag, or you just have too much at the nose?
I DD a '20 F350 SRW/Super Cab/8' and sometimes pull my 26' Aluminum Sundowner car trailer. I cannot even get the back end of my F350 to move down during my tows. (please verify), but the only rear suspension difference between a F350SRW and F250 are spacers and one leaf. This maybe the easiest OEM thing to do to help the back end of your F250.
And yes, I am familiar with your part of the world and the west-east high winds. I have had my guys parked around Cheyenne/I25 due to high winds many times...
Best of luck.
Best of luck.
Best of luck.
From everything I read the 2020-2022 F-250 with High Capacity Towing Package is identical to the F-350 suspension/frame wise. That was not the case on the 2017-2019 when the 250 was softer even with the high cap tow package. Maybe FX4 makes a difference as I do get about 2" of sag right off the bat, even with the trailer empty.
I would highly recommend a tongue weight scale. It's not safe to calculate or estimate your tongue weight.
https://www.sherline.com/product/she...-weight-scale/
Is the one you posted only for Gooseneck and 5th wheel trailers?
The is also a 2x4 + bathroom scale trick you can use.
Does a bathroom scale go that high? My tongue weight with the trailer fully loaded, properly balanced at 10-15%, would be 900-1300 lbs.
