Trailex VS Featherlite
Is there any major difference between them? Or are they basically the same? Or go enclosed?
IMHO go enclosed. And look at other companies as well.
Trailex is a little bit lighter. If you have a mid size pick up or a SUV that has 6-7k pound towing max, go with the trailex since that will keep the weight as low as possible. But definitely consider going with an enclosed if you have the means. If you have a bad back get an ATC or Intech enclosed with the swinging door.
