BBS E88 Rims / Powdercoated Black
  • Wheels and Tires/Axles - BBS E88 Rims / Powdercoated Black - Used - 2009 to 2011 Porsche 911 - Freedom, PA 15042, United States
swartzzz is offline
    $4,000
  • Location Freedom, PA, 15042, USA
Porsche 911 2009 - 2011
For sale is a set of BBS E88 Wheels and / or BBS E88 Wheels and Nitto NT01 Tires and TPMS monitors installed. Tires have 4 heat cycles and are GT3 Fitment sized: 335/30/18 and 275/35/18
These were re-finished and used for two track events. The centers were new, the rim halves were used and re-finished black. Also have another set of 2" rim halves to go with the set to make them a bit MORE aggressive. Set up today as:
0288274 / 1.0 outer half / 8.0 inner half with an ET + 50.0
0288108 / 2.5 outer half / 9.5 inner half with an ET + 64.0
Tires are NT01 Nitto's. Sizes are 335/30/18 and 275/35/18. They have very little track time on them since the refinish.
Wheels and tires and TPMS as is: $4000
Wheels ONLY as is: $3000
May be able to meet in the MidWest / NorthEast, as I travel a great deal for my work! Located north of Pittsburgh, PA
I use the below as the most amazing fitment list:
996 Cup 1999-2001
Front: Center 0229021 Outer Ring 1.0" Inner Ring 7.5" ET + 45.5
Rear: Center 0229021 Outer Ring 1.5" Inner Ring 9.0" ET + 58.5
996 Cup 2002-on
Front: Center 0229052 Outer Ring 1.0" Inner Ring 8.0" ET + 47.0
Rear: Center 0229052 Outer Ring 1.5" Inner Ring9.5" ET + 59.5
997.1 Cup
Front: Center 0229066 Outer Ring 1.0" Inner Ring 8.0" ET + 43.0
Rear: Center 0229066 Outer Ring 2.5" Inner Ring 9.5" ET + 43.0
997.2 Cup
0229066 / 1.5 / 8.0 ET + 36.5
0229066 / 3.0 / 9.0 ET + 30.0
997 Carrera S Less aggressive / standard brake
0288120 / 1.0 / 7.5 ET + 49.0
0288107 / 2.5 / 8.5 ET + 55.0
997 Carrera S More aggressive / PCCB
0288274 / 1.0 / 8.0 ET + 50.0
997 Turbo Less aggressive / Standard Brake
0288108 / 3.0 / 8.5 ET + 44.5
997 Turbo More aggressive / PCCB
0288107 / 3.5 / 8.5 ET + 42.0
997 GT3 non Center-lock
0288108 / 2.5 / 9.5 ET + 64 w/o factory 5mm spacer
0288107 / 2.5 / 9.5 ET + 68 for use with factory 5mm spacer (effective ET is + 63.0)
997 GT3 RS non Center-lock
0288108 / 3.0 / 9.0 ET + 51 for use with factory 5mm spacer (effective ET is +46.0)
997 GT3 Center-lock
0201182 / 1.0 / 8.0 ET + 43.0
0201183 / 1.5 / 10.5 ET + 61.0
997 GT3 RS Center-lock
0201183 / 2.0 / 10.0 ET + 48.0
Cayman Street / Track day car
0288107 / 2.5 / 7.5 ET + 42.0 for use with factory 5mm spacer (effective ET + 37.0)
Cayman Interserie car uses same rim combos with specific centers for lower ET's
Cayman S aggressive track day fitment
0288107 / 3.0 / 7.5 ET + 36.0
Old 11-23-2018, 11:51 PM
slavik
slavik's Avatar
Would they fit 997tt?
slavik is offline
Old 11-24-2018, 04:04 AM
310JAY
310JAY's Avatar
The rears in the pictures are 0288108 not 107 so if I'm not mistaken made for standard brake fitment but I would double check with a pro.
310JAY is offline
Old 11-24-2018, 10:55 AM
swartzzz
swartzzz's Avatar
I made the adjustment. Thanks! Sorry about that!
swartzzz is offline
Old 11-29-2018, 06:32 PM
swartzzz
swartzzz's Avatar
New Price.
Package - $4000
Wheels ONLY - $3000
swartzzz is offline
Old 12-15-2018, 02:27 PM
swartzzz
swartzzz's Avatar
Bump! Its soon to be CHRISTMAS!!!!!
swartzzz is offline
Old 01-18-2019, 08:22 AM
swartzzz
swartzzz's Avatar
Bump. I have some Continental Slicks I am willing to part with as well!
swartzzz is offline
