Porsche 944 Race Car
1987 Porsche 944
  • 1987 Porsche 944 - Porsche 944 Race Car - Used - VIN WP0AB0942HN477516 - 4 cyl - 2WD - Manual - Hatchback - Gray - Roswell, GA 30075, United States
3rd Gear
tlpearson is offline
    $8,900
  • Location Roswell, GA, 30075, USA
  • VIN WP0AB0942HN477516
  • Engine 4 cyl
  • Vehicle Type Hatchback
  • Exterior Color Gray
PCA Club Race SP2 Legal. Only 10 hours on smooth running rebuilt parts-matched engine. Car built from the ground up from a never damaged chassis. Gray color, ready for your team wrap.
DE's used to sort car, never raced, 1:29 at Atlanta Motorsports Park, 1:46 at Road Atlanta
Car delivered with Road Atlanta setup
This car has over $10k in new and rebuilt parts, brakes, every bearing, and even many new bolts.
~2400 lb. empty weight (well under 2600 lb. class minimum that includes the driver)
ENGINE
Re-built engine, all reciprocating parts matched within less than 0.5 gram
1988 factory forged pistons, 11.5:1 compression ratio
Injector flow rates balanced on dyno
Magnecor racing spark plug wire set
A/C deleted using factory bracket
Heat wrapped exhaust headers
Custom exhaust with cat removed
Magnaflow muffler
Remote Setrab oil cooler, duct mounted, 951 oil filter adapter, temperature sensor / gauge
Injection fuel lines covered with fire-proof $30 per foot Aeroquip Firesleeve material
Solid engine mounts
TRANSMISSION
1989 short fifth gear transmission
Shift linkage modified for precision shifts
Quaife Torsen Differential (automatic torque biasing helical gear)
New half-shafts and CV joints
Solid transmission mount
SUSPENSION
Manual steering rack
Charlie arms with new bearings
Racer's Edge full set solid bushings front and rear
Elephant racing torque tube trailing arm bronze bushings with grease fittings, no torsion bars
Wheel bearings all new front and rear
Corner balanced to less than 10 lbs. variation between wheels
KNA Front tower brace
Racer's Edge adjustable camber plates
Koni double adjustable front coil-over race struts, custom valved for spring rates by Koni
Koni double adjustable rear coil-over race shocks, custom valved for spring rates by Koni
Hypercoil springs front and rear
Stainless steel braided brake lines
Weltmeister adjustable anti-roll bars front and rear
Car delivered on 7.5x16 and 9x16 Club Sport wheels, tires are worn and not for use on track
BODY
Brake ducting from spoiler fog light openings to front brake rotors via backing plates
Sun roof replaced with welded-in factory roof panel
Oil temperature gauge
New radiator
New alternator
New battery
Full roll cage
Battery cut-off switch PCA legal
Momo race steering wheel with quick disconnect hub, radio push-to-talk switch
Wired for radio, including mounting box and antenna (no radios provided)
Traqmate TraqDash GPS Data Acquisition System, with TraqData analog/digital data acquisition module wired for brake actuation, throttle position via engine management computer
MyLaps transponder
Wink mirror
Wiring harness reduced for weight savings
Heater core removed, vent fan rewired to separate dash toggle switch
Sparco Circuit VTR seat with race mountings and roll bar mounted adjustable seat back brace
Corbeau passenger seat with race mountings
Car will be delivered with either new or certified re-webbed five point seat belts
CLICK HERE FOR MORE DETAILS
Old 06-30-2019, 11:05 PM
Tim the Engineer
Tim the Engineer's Avatar
PM'd Twice. No response. ??
Old 08-05-2019, 01:15 PM
kmracing
2nd Gear
kmracing's Avatar
Default How can I reach you to discuss your car?
Hello, I am new to Rennlist ads and not sure how to communicate with you about your car for sale. Please advise. Thank you, Jeff Stone
DE's used to sort car, no races, 1:29 at Atlanta Motorsports Park, 1:46 at Road Atlanta
Don't confuse this car with a typical club racer built from a worn out or damaged chassis, or one raced for a season or more. This car has over $10k in new and rebuilt parts, brakes, every bearing, and even many new bolts.
ENGINE
Magnaflow muffler
TRANSMISSION
Quaife Torsen Limited Slip differential
SUSPENSION
Car delivered on 7x15 wheels, ready for your 18" wheels and P225/40ZR18 P245/35ZR18 tires for best performance.
BODY
New radiator
New alternator
New battery
Full roll cage
MyLaps transponder
Wink mirror
Old 08-05-2019, 01:29 PM
944Cup
944Cup's Avatar
To contact seller, just click on remember name, tlpearson, and you will be able to send the seller a private message.
If you have any other probs reaching them, email me at cup944@aol.com.
Old 08-12-2019, 01:19 PM
tlpearson
3rd Gear
tlpearson's Avatar
Send a private message and I will give you my phone number.
https://rennlist.com/forums/members/...tlpearson.html
Also advertised here:
http://peachstatepca.org/classifieds/20
and here:
https://www.pca.org/classified-ad/329777
You can also contact me here:
http://peachstatepca.org/MailClassified/20
