Intro to Electric Powertrains
#61
Most people know that Elon Musk has a habit of over-promising, but this is a huge issue for investors and buyers waiting for their cars. How many customers will cancel their orders?
Where will Porsche source their batteries, motors and control systems and how reliable will those sources be when the Mission E goes into production?
Everyone else is getting batteries from "not Panasonic". Tesla's control systems are in-house and we're nowhere near capacity on circuit boards, etc. Globally we're also nowhere near capacity in motor supplying, so I'm not too worried - the price of batteries is a bit more of a concern, but it's still not too bad.
#62
be delivered for less than $45K, and at that price Tesla loses money.
i.e. surely you don't imply that Tesla designs & manufactures all the ECUs used in the vehicle
(ABS, suspensions, locking units, seat modules, etc.). GM is highly integrated with Delphi & Delco,
but still uses multiple outside sources. Delco can even produce semiconductors which Delphi
can use for their ECUs. Even Apple until recently became more vertically integrated
with their purchase of a wafer fab facility.
Yes, Tesla with the help of Mobileye and now Nvidia for AI contributed to the AP system,
but must rely on Nvidia for their processors. Tesla has nowhere near the design resources
as Nvidia needed for AP1/AP2. Even for batteries, Panasonic must 'hold' Tesla's hand
even now at the Giga plant.
Tesla has nowhere near the required financial wherewithal now to become highly
integrated, i.e. their cash flow is negative and they're near being credit limited.
The Tesla hyperbole never ends!
#63
part sources, e.g. ECUs, body parts, which is NOT the case for Tesla. The reliability of automotive
systems for the last 10 years far exceeds that of the prior 10 years, which Porsche has
and will benefit from with the Mission E product. Ask a Tesla Model X owner how reliable he/she
considers it.
#64
My X is very reliable. But the early ones were not as with all things tesla they get their act together after making about 30,000 of them.
#65
Also battery degradation seems more fear than fact - other than leafs the BEVs with thermally controlled batteries are showing no major problems even after 7 years (Tesla roadsters and 5 year old 200,000 mile S’s) - what ever there is, is manageable and the rough schedule and cost to fix/replace is in line with major ICE component age relayed failures like transmissions/engines...
The leaf on the other hand sucks - but root cause there is lack of active thermal management.
Does anyone have actual data that is showing an actual problem for BEVs other than leafs?
#66
That's basically the extent of Tesla's vertical integration (motor & battery electronics),
Regarding the Gigafactory, it turns out making batteries isn't trivial. Who knew!
The Tesla hyperbole is the main reason I don't own any of their stock. Don't get me wrong, I think they're doing a lot of things right, but hype based on a guy who spends all of a couple hours a week thinking about the company seems very silly to me.
Remember, Porsche is part of VW/Audi and benefits from their economies of scale and
considers it.
considers it.
As far as reliability goes, Tesla does a great job with the drivetrain - not perfect, but best-in-class for what's available right now. It's everything else, and the 3 Fs of form, fit, and finish, that are pretty terrible - especially for the price - and cause the vast majority of issues.
As an amusing aside, one of my former battery systems teammates was formerly at Tesla, and after the Model X was released told us about the weekly updates meetings in his team, which included a segment called "This Week, in Falcon Wing Doors" during that development cycle.
#67
Have another ICE car as a daily beater for now, really wondering how long the delay will be next year before I see my model 3.
Depending how the Mission E performs and what it costs, I’d certainly consider switching to that as my daily driver in 2020 or so.
#68
if their race design team received consulting from Tesla's Model X engineering.
#69
Another big assumption we in the industry make is that the battery is always discharged to minimum and charged to maximum for a given cycle. FYI, you probably shouldn't do that regularly - hovering around 70% SOC brings considerable lifetime advantages.
The Leaf pretty nicely illustrated to OEMs that active thermal management is necessary, which is awesome because I get the approval to implement a thermal management system without even needing to ask. Of course, I need to engineer every last penny out of it, but suppliers are pretty used to that ball game these days so "material cost plus processing cost plus a squidge" ends up being somewhat reasonable.
It turns out that the highest RMS current you'll ever see for more than a couple minutes in any EV, outside of a couple edge cases that I've literally never seen in any field data, is during fast charging. This means that the cooling system I need to engineer every penny out of also has really well defined power dissipation requirements, which makes it even easier to develop. I'm not going to say the design is an afterthought - it's literally central to the design of every module I've seen - but it's definitely negligible in time spent relative to, say, the plastic bits that hold the cells in place.
#70
have sold with a major range reduction, e.g. 20% - (84 to 67), using TM? Besides, the Leaf's
chemistry is less volatile than Tesla's and Tesla's battery is generating more internal heat
(MS's weight) than for the Leaf, i.e. they both have the same internal resistance,
where battery heating is; Power = I^2 x R). Given that and Tesla's higher charging currents,
that additionally requires TM. And then you have the added cost factor of TM for the Leaf.
Yes, many factors are involved.
#71
Was going to bring up the fact that battery degradation has been pretty minimal in Teslas with their thermal management systems; even the earliest Tesla owners are reporting pretty small losses at 100K of driving. But you guys beat me to it...
Interesting article with Porsche's CFO talking about the difficulties they face in catching up with EVs (and it's Tesla, no doubt, that they are primarily talking about). Make no mistake, this is a very big, very serious undertaking, even for Porsche:
"Porsche admits EV investment to take on Tesla is an “enormous burden”"
https://www.teslarati.com/porsche-mi...le-investment/
I, for one, hope that the Mission E turns out well and that Porsche can make the quantum leap to electric tech.
#72
I’m looking forward to trading in my model S for a mission E - but for now the S is way better than a panamera.
#73
The Chevy Bolt is a pretty good BEV in the Model 3 car class and can be had quite a bit cheaper than a Model 3, and can actually be had. Lease are butt cheap and 3 years will get you to just about the right place where more BEVs are coming to market.
It’s also quite peppy and an all around decent car.
#74
#75
The "fun" of owning a BEV (from an EV website):
Luckily, I haven't yet experienced that situation, but wouldn't want to be on the I5
needing to use a SC near the Grapevine or Harris Ranch on a holiday weekend.
Some are totally inconsiderate "needing that last electron" from the SC.
Re: Tesla Supercharger Network
Report this post
Quote
Thu Nov 02, 2017 10:15 am
I experienced my first congestion delay at a SC last weekend.
I ended up on an unplanned 200+ mile trip to L.I. last weekend. I drove down without a stop and had about 30 miles of range remaining when I arrived. I needed to spend the day with family and planned to return home in the evening. For the return trip I needed about 20 minutes at the Syosset SC in order to be able to reach a SC in CT.
When I got to the Syosset service center I found all four SC stalls in use and 3 more cars waiting in line. Most of these cars looked to be locals doing their "weekend charging". Two of the people waiting were playing chess (!), another guy had a book, and a third person was walking his dogs while his X charged. I suspect the Saturday afternoon congestion there is common.
Thankfully I didn't need to wait and I came back 2 hours later when all the stalls were empty. My initial mistake was not looking at the dash beforehand to check the occupancy of the SC stalls. There's a new SC planned for the area (possibly at the mall) that will help in the future.
Report this post
Quote
