(Note In This Tutorial You Will See 1 Mini Cause The Store Only Had One ATO)
Instruction:
Mount The Camera Front
Wire Routing:
Front Camera
Feed The Connector Side Wire From The Right Footwell Fuse Box Area To Right Fuse Box Area Then Up To The Passenger Side A Pillar Weather Stripping To The Windshield Roof Liner
Wiring:
Fuse Box Panel
Open The Full Fuse Covering
Remove The Pink Fuse Holder – Top Two
Right Footwell Fuse:
Row A #12 ‘BCM Control Unit (RHD Vehicles)’ (ACC Wire Tap) & Row B #1 ‘Gateway Control Unit’ (Battery Wire Tap)
I have been using them since 2017 from Mercedes, BMW, Porsches to Lambo so far one of the best.
ok I think with all the ****ty stuff that happens here (SoCal) having 2ch in the dailies wouldn't be a bad thing. I've installed other electronics in cayenne and macan and 911 so the approach looks similar on the taycan.
