20k miles service interval
Just received the following regarding the 20k service interval on my 2021 TSS from my south FL Porsche dealer:
Cost $857.25
I think the only important thing is the flushing of the brake system, but does it really need it at 20k miles?
Cost $857.25
Dr. G7 (09-20-2022)
I think I prepaid for my 2 year in the deal for like 1/2 that.... is what it is, I'm ok with someone spending a few hours looking over things and making sure its good.
I paid around $300 for the service. Bought my own wiper blades and filter from Suncoast, told them to skip the brake flush unless the fluid tested out bad. It didn't, at 1 year / 18.5K.
While brake fluid does degrade over time it does not happen in 20K miles. Every 4 or 5 years is reasonable. I have never changed the brake fluid in any of my vehicles and some had well over 100k miles on them when selling and never had any brake problems. Everything else on that list can easily be done yourself.
It's not degrading, it's absorbing moisture.
UMMMM - it's an EV - this is way over priced for doing an "inspection" - the only process of ANY substance there is the brake flush…
Sounds like OP's dealer is doing a good job of upselling. I wonder what the factory maintenance schedule requires? Brake fluid replacement is generally a time-based event (i.e. every 2 years), not a mileage-based event.
but honestly none of this other than brake fluid after 2 years is required.
it's a good gig and good money if you can get it.
A simple tester like this one below is all you need to determine when to flush brake fluid, especially for a car that is used solely on the street and not the track:
Personally, I will skip the dealer inspection and log in my own inspection on Carfax. I will change all filters, wipers and other consumable parts, along with blowing out all drain lines. I routinely do my own maintenance on my track car, so I am comfortable skipping the dealer work.
The following 2 users liked this post by 991carreradriver:
daveo4porsche (09-23-2022),
PierreTT (09-24-2022)
https://www.amazon.com/OTC-Tools-459...23158893&psc=1
For example, I will take the OP's invoice, scan and create a checklist. I will date and initial the work performed and upload it with the invoices for purchased parts, filters, brake fluid and so on.
I leased my Taycan. As an early adopter, I was concerned about residual value if I purchased - now not so much. I will purchase this vehicle at the lease end and keep it for a few more years. It is a very high spec for a RWD and would cost well over $30k to replace it new with a RWD, given the loss of the MSRP discount I received, Federal tax credit, base price increase, option price increase, cost of money and probable Admin add on. I am not even factoring in that my residual is probably $10-15k less than a dealer will give me for it in 22 months. Plus my car only has 10k miles on it and other than one LTE comm issue, now resolved it has been trouble free.
All that - and they don't even rotate the tires?
About the only routine maintenance an EV should need is tire rotation/air pressure checks, and adding windshield washer fluid as needed. Cabin filter every few years too.
