Question regarding Off-Road Design Package for 4S Cross Tourismo
Specifically does the 11mm increased suspension ride height in Normal apply to Lift setting as well? I am looking for the ability to raise the ride height to avoid chassis damage from potholes on an un-paved road that is a short-cut to get home. It would be nice to have ~36mm in ride height adjustment range, but I suspect that isn't what Off-Road Design is about, though.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
The following 2 users liked this post by Visceral:
aCayenneFan (06-21-2022),
Der-Schwabe (06-20-2022)
Thanks in advance.
Thanks in advance.
Huh? How does a raised ground clearance collect dirt and road debris? Are you driving on open fields? Serious question. My Cayenne with higher ground clearance than the Lift mode of the Taycan CT has no more dirt on it's drivetrain than my AWD car (E90 BMW335ix).
I mean dirt accumulating in the gaps between the plastic “fins” and the body.
