4 Zone Climate Control
Old May 28, 2022 | 01:14 AM
TXSchnee's Avatar
TXSchnee
Default 4 Zone Climate Control
Sorry if this was already asked, I didn't see anything when I searched. Is there any difference in the compressor units between the standard 2 zone and the 4 zone climate controls? In the Cayenne, the 4 zone gives you a larger compressor, which makes a difference in TX, wondering if the Taycan is similar, or if the 4 zone is just the touch screen controls and the same compressor. TIA
Old Jun 4, 2022 | 08:28 PM
dasams's Avatar
dasams
If you can find the tech specs, check on the amount of refrigerant. For the 2021 Cayenne, the base system has 680 gr of refrigerant while the 4-zone has 850 gr, a 25% increase.
Old Jun 10, 2022 | 07:07 PM
JAGMAN1's Avatar
JAGMAN1
Cayennes have as second evaporator core in the trunk, Taycan prob uses a similar approach. That's why it needs more refrigerant. Not sure whether the compressor is the same or larger. If I had to guess, I'd say they are the same size.
