I have this whistle noise on the driver side when the speed gets above 60 km /h on my Porsche Taycan Cross Turismo 2022 mod, anyone with same experience and found any solution ?
Drive slower?
I kid. I would check the rubber sealing strip on your driver side door.
I had a similar issue on another car and it was the windshield. There was a leak in the seal and air was forcing its way in at speed. So was water! Not good.
On TaycanForum some user have reported that adding a piece of insulation foam tape to the front lip of the frunk essentially solves the whistling problem.
I used black electric tape and on the seam between the black plastic (where you put the foam tape) and the painted part of the bumper and the noise went away. I think you have to cover that seam (just to the left of the tape in your photo).
