Radio problem
When turning to the Radio function to listen to FM I get a blue spinning wheel and "loading data" message that goes on forever. I can listen to the radio but it doesn't display the station. Help!
See post below before you doing a full reset. You could try to reset the PCM and see if that helps. Check your manual on how to reset..
Here is a vid on Taycan reset
Before you do a factory reset, which may result in a loss of all your personal settings try a PCM reboot. Place two fingers together in the upper right hand corner of the PCM, on the clock. It may take a few attempts to get it to work. The PCM will go dark and reboot into an engineering screen. Click on the last option to reboot the PCM. The whole process should take a few minutes. Good Luck.
