Trip Report: Impressive Results in Taycan Turbo S with Range Mode
I have over 7k miles on my Turbo S, but I recently started trying range mode on a couple of road trips. This weekend I drove 248 miles each way across central and western Colorado. All country roads (45-65mph speed limits) with lots of elevation. Several mountain passes including Monarch pass at 11,312ft. Temperature was in the high 80's to mid 90's so I was using the cooled seats and A/C the entire drive. I drove 5-10 mph over the speed limit when possible. I also had two passengers and about 200lbs of gear. Keep in mind this is a Turbo S with 21" wheels, and an EPA rated range of 192 miles.
Results:
Manitou Springs to Montrose Colorado
Distance: 248 miles
Efficiency: 29.9 kWh/100miles
Avg Speed: 47mph
Total Range based on efficiency: 280 miles
(assuming 83.6kWh of usable battery)
Montrose to Manitou Springs Colorado
Distance: 248 miles
Efficiency: 29.1 kWh/100miles
Avg Speed: 53mph
Total Range based on efficiency: 287 miles
Both times I stopped briefly in Salida Colorado and used a 125kW Chargepoint Fast Charger to add about 15%. I could have easily made both directions on a single charge, but we needed a break and this charger is in a convenient location at the half way point.
In the past using Sport/Sport Plus mode I have averaged closer to 36.0 kWh/100miles along the same route. Needless to say I have been really impressed with range mode. I have it set to the 85mph limit, but it still has more pickup than just about any car I've ever owned. I did switch to Sport/Sport Plus mode a couple of times when I was planning on passing someone and didn't want to hit the 85mph limiter. Otherwise range mode was great.
The Taycan continues to impress.
Results:
Distance: 248 miles
Avg Speed: 47mph
Distance: 248 miles
Avg Speed: 53mph
The following 9 users liked this post by manitou202:
daveo4porsche (07-08-2021),
Der-Schwabe (07-05-2021),
DKP 97 C2 Coupe (07-07-2021),
lexbro (07-29-2021),
Needsdecaf (07-10-2021),
and 4 others liked this post.
~3.4 miles per kWh is pretty solid.
The following 2 users liked this post by spdracerut:
XLR82XS (07-08-2021)
Any issues with charging? Plug-n-charge work? I'm taking my RWD from S. Florida to PEC Atlanta in September.
that said, the loaner I had while they were trying to diagnose my problem was a RWD base model and it would plug and charge without issues.
the only other concern is that there are still issues with the EA units being down.
overall you shouldn't have an issue on your trip
